2000 Camaro SS build First Post
A lid....into a ported throttle body(55$)... into a ls6... into some Lts is a nice exhaust setup...catback still questionable but atleast you have one... New gaskets for the intake..... Motor mounts..... Remove air/egr if you have no emmissions.... New bosch rear o2 sensors..... and a frost tune. === good typical setup/gains and ready for heads/cam at that point.
The camaro section is only for the 5th gen. Our 98-02 fbody (Any and all Trans ams/camaros) share all the same componets. Their the same car with a different body style.
Upon a closer investigation I guess that this is the right place for this.
Before
After
First I removed the EGR. Where it connects to the intake it is a 10mm bolt. My EGR was connected to the block with a 15 and 16mm bolts I suspect it originally was both 15mm bolts and somewhere along the road that switched. It connects to the header with 2 10mm bolts (these are a bitch to get to you'll see the contraption that I rigged together to reach them).
Here is Step 1, remove this bolt
Next remove the bolts that connect the EGR to the front of the block, 15mm, maybe 16mm on bottom. Also unhook the electrical connector, some people say cut it off and tape the wires I just tucked it away.
Last step remove the 2 10mm bolts that join the apparatus the the passenger header. You'll have to most likely jack-up the car to get the bottom one. Spray it down with some penetrating lube if you have it. I only had WD-40 and the bottom bolt snapped off.
I ended up taking off the passenger side air, where it joins the header to give me some more space.
Green is EGR, Blue is AIR
My contraption to reach the bolts, fyi if you don't have a flex-head ratchet buy one.
All done, if you're like me and replacing the original headers there is no reason to get cover plates. (Unless you change your mind and buy eBay headers to save money, then you'll need the cover plates.)
For reference here is the passenger header connection
The drivers side connector also 2 10mm bolts
After you get those two off you'll have to remove the electrical connector, then dismount that box which is held on by 1 10mm bolt and un-hook the air hose from the rear of the intake. I'm replacing my stock intake so I'm not worried about plugging that hole, if you aren't replacing your intake I'd leave the hose on and clamp it off.
Un-clip that and remove the box that it was plugged into 1 10mm bolt
Unplug the rear
Next pull everything out of the way and get to where the airlines feed to right behind the drivers side headlight.
You'll have to jack up the car again and remove the shround from underneath. 9 10mm bolts.
Now you can see the pump which is held in place by 4 10mm bolts.
Make sure to pull the hose off this thing, not sure what it does but I'm nearly certain I'll be pulling this out soon too.
EGR/AIR crap
I used this picture a lot for reference I borrowed it from: TRANSdAMn 2k, that was posted here https://ls1tech.com/forums/new-ls1-o...uestion-2.html post #32. I re-hosted it just in-case somewhere down the line he deletes the original.
Agreed with the other tech guys, that definitely looks like a flowmaster exhaust. You can get a nice magnaflow system here from one of the vendors for around $450 shipped. That'd be a nice, cost effective upgrade. Once you get that completed, I'd start looking at suspension items as well as some TSP 1 7/8" headers and ORY to complete your exhuast.
"Westech's Superflow showed our V6 with the Flowmaster American Thunder exhaust system gained a hair over 11, horsepower (SAE-corrected) at the rear wheels and road test numbers backed that up. Using a Vericom VC3000 Performance Computer, an on-board vehicle dynamics tester, we saw 0-to-60 time decrease from 7.83 to 7.44-sec. and quarter mile stats going from 16.15-sec./89.14-mph to 15.87/90.69.
Eleven horsepower and nearly two tenths and a mile-and-a-half an hour in the quarter is an outstanding improvement for just an exhaust change on a car which, in stock trim, made only 162-hp (SAE) at the wheels. Clearly, the O.E. exhaust is restrictive. "
http://www.camarohomepage.com/project/part1.htm
