Customizing CAI Fbody
Old Mar 17, 2013 | 08:04 AM
  #81
lemons12's Avatar
Originally Posted by dr_whigham
^^ Is that a Halltech KB? Hard to read...
Looks to be one..
I was just clearing my inbox.. Came across your warning message with the "poo poo head" from the visitor messages. I got a good laugh, again!
Old Mar 17, 2013 | 11:11 AM
  #82
PUNISHER TA's Avatar
Its a Halltech MF107R.
Old Apr 1, 2013 | 01:43 AM
  #83
DopeFedZ's Avatar
Originally Posted by lemons12
On comp now..
Correct, identical to that. ^
I think the 4" tube coming down would be decent.. But if I could find a good, non-ghetto, way of sealing it to the section I cut out, that would be ideal.
But come to think of it, none of the other ram airs are sealed at the bottom... They are just open to the air like the velocity stack would be.
I started making this but didnt get around to finishing it. Was just one idea i had initially. I would make it a little different now and just run the ine tube right to the center instead of one on each side.
Old Apr 1, 2013 | 01:49 AM
  #84
lemons12's Avatar
Carlos, where yours touched the bumper was it sealed or just sitting close to it. I'm assuming you were going to seal it judging off the wavy cut.
What are you running currently?
Old Apr 1, 2013 | 10:14 AM
  #85
Jadedbird's Avatar
I need to find a good write up on the fuse box relocation. The one i found is crap
Old Apr 1, 2013 | 04:35 PM
  #86
DopeFedZ's Avatar
I was going to seal it. I dropped it off to get welded and it never did. It is still at the shop on the backburner.
Right now i run a 4" tube with a velocity stack directly behind the mesh plate insert.
Old Apr 1, 2013 | 10:24 PM
  #87
MM98's Avatar
Here's mine I'm working on... Aluminum 4" tube & fabed the radiator support from a LT1 car & sheet metal.
Old Apr 1, 2013 | 10:45 PM
  #88
djfury05's Avatar
The efficiency of a CAI is all in how its designed. The less bends and turns and less bullshit the better it will perform.
Old Apr 1, 2013 | 10:54 PM
  #89
lemons12's Avatar
Ever get anything with the 4" tube VS a lid setup? I'm curious...
Old Apr 1, 2013 | 10:58 PM
  #90
djfury05's Avatar
If you can talk Chrs1313 to come in here and elaborate on all the extensive testing he did on this very subject I'm sure there would be some doubts laid to rest. The intake I have on my car was designed by him and I improved upon it to fit my needs.
Old Apr 1, 2013 | 11:01 PM
  #91
lemons12's Avatar
So through his testing he found that a CAI setup similar to yours performance wise is better than a 98m no MAF chrs1313 setup?
Old Apr 1, 2013 | 11:07 PM
  #92
djfury05's Avatar
I can't remember all the testing results he had that's why I said we need to get him in here. At one point I remember him having a lid/CAI hybrid setup that worked good.
Old Apr 3, 2013 | 05:20 AM
  #93
jesse92's Avatar
Heres mine.
Old Apr 4, 2013 | 02:38 PM
  #94
studderin's Avatar
here my setup. I wanted to keep the stock look of the plastic rad holder/lower airbox. And run a good filter setup for street driving in the rain, dirt roads, run a maff for all year and not have to change it for a track only setup.
SUX2BU camaro duct setup, sealed to a trimmed and ported stock lower airbox with a clean paper filter.
SLP lid, inside smoother a little, 4" 22* trimmed bellow, to 92 or 102mm TB. With or without a maff cam be used, on lower OEM style car intake.
custom lid for taller intakes. Can use a stock filter, (gains nothing at the track pulling it, the airbox get pressure in it) Maff or SD, and running a bellow that was testing NA to make more power then others style (radius = decreasing percent, and taper after that) on the dyno (new era, same one used on all the intake/lid/over the radiator style intakes setups for a few years now other cars) And at the track gains more MPH then other styles. The shorter and straighter the better. And getting the coolest clean air the better, not in the engine bay, or near or on the rad. AC condenser, auto trans cooler ect.
friends car powdercoated wrinkle black
here are some other setups
Old Apr 11, 2013 | 12:31 PM
  #95
3YLSYKR's Avatar
That's a cool setup. Has a big mouth on it. Nice fab work as well.
