Mpg question
Old Mar 11, 2013 | 12:58 PM
SSCamaro99_3's Avatar
Originally Posted by z28SSilvest
Yeah thats exactly what I was thinking! Not worth it in the long run and like it was said above, I didn't buy the car for mpg, but it is my daily driver so sometimes ill ride close behind a truck or something just to get a few miles lol
I would still just go to neutral instead of downshifting. Why beats up parts for no reason?
Old Mar 11, 2013 | 02:29 PM
slow ride 02's Avatar
I read somewhere that knocking in to neutral and coasting to stop uses a slight amount more gas. To save a small of gas, it said to leave it in gear and use the brakes. It said the pcm cuts the gas this way. Is this true? Hell I know!
Old Mar 12, 2013 | 11:35 AM
TImmy_Jones's Avatar
Not sure how that would work...but I pop it in neutral as I pull up to a stop sign or just hold the clutch in.
Old Mar 12, 2013 | 12:14 PM
Let's assume by staying in gear you are maintaining 2000 rpms, and by going to neutral you are at 850 rpms. The injectors would have to be pumping out 2.35 times the fuel to maintain idle, than to maintain 2000 rpms. Just does not seem reasonable.
Old Mar 12, 2013 | 01:31 PM
Ferocity02's Avatar
I almost always downshift and coast in gear to stops so I'm using DFCO. The savings in fuel are negligible IMO. I might get into the habit of coasting in neutral to keep my clutch happy.
Old Mar 12, 2013 | 02:00 PM
About 5 mins in is where he talks about the fuel cut-off while braking.
Old Mar 12, 2013 | 02:03 PM
brnmw's Avatar
Originally Posted by JohnS Z28
You didn't buy a v8 sports car for mpg haha. But no probably not more than a half mpg. But yes it's a good habit for a healthier trans/clutch
This. ^^^^^^
Although I will say even driving around in a muscle car, I do actually try to get the best mpg as possible.... especially now till I get my usual everyday 4-banger working again.
Old Mar 14, 2013 | 06:37 PM
LT1559's Avatar
OP, I throw it in neutral while coming to a stop, cheaper to save money on brake pads than clutch.
Old Mar 14, 2013 | 09:59 PM
Grimes's Avatar
Depends on the driver of course, but I downshift most of the time to slow down (fun!) and my original ls1 clutch lasted over 100k miles....
Old Mar 15, 2013 | 07:57 AM
redtan's Avatar
As soon as you push the brake pedal in an auto car, the torque converter unlocks and RPMs drop to basically idle level.
No it doesn't, where'd you get this wild idea?
This may be the case if the converter was never locked up to begin with, but if you're cruising on the highway with the converter locked up and you let off the throttle to either coast or start braking the converter doesn't automatically unlock. There are certain throttle position and MPH criteria to be met before the converter unlocks.
Old Mar 15, 2013 | 08:27 AM
Rauq's Avatar
In an M6, if you're coasting while in gear, under certain conditions (RPM range, usually over a certain RPM, like 1200, and a MAP range, say less than 600kPa), deceleration fuel cut-off (DFCO) will shut off all the injectors, so you're using no fuel.
That being said, you don't need to downshift to 3rd if you're coasting at highway speeds (obviously). You'll probably save more $$$ on engine wear than fuel by not doing that. I usually drop it to 5th and ride that out, or maybe 4th if I'm not on the highway.
Old Mar 15, 2013 | 01:04 PM
  #32
How exactly is the engine remaining running with no fuel?
Old Mar 16, 2013 | 12:59 PM
  #33
Rauq's Avatar
It's just an air pump at that point. The transmission is keeping it spinning, at whatever rpm the speed of the vehicle and the gear you're in determine, so to make power again all it has to do is turn the injectors back on, whether it's because you hit the gas or take it out of gear.
Old Mar 18, 2013 | 02:21 PM
  #34
brnmw's Avatar
+1
*Happysem: Tap the brake pedal when doing about 100 mph+ in an Auto car and tell me your RPM's dropped to idle level. (Never seen that before.)
If you are doing est. 130-160 mph in any auto trans car (well maybe not any) typically your rpm range is going to be well into the est. 4-5k range in 4th gear respectively (Since Auto Trans.) and don't go below that till the car has slowed significantly. > Unless you got some aftermarket T. Converter that does this feature?
Heck the new Camaro SS 6-speeds are in 5th gear doing 155 mph @ est. 5,300rpm and don't go below 4k Rpm till you switch to 6th gear.
Old Mar 19, 2013 | 08:31 AM
  #35
ckpitt55's Avatar
what is this "slowing down" phenomena you guys are speaking of? i've never heard of this.
Old Mar 19, 2013 | 10:29 AM
  #36
z28SSilvest's Avatar
Coming to a traffic light, stop sign, etc.
Old Mar 19, 2013 | 12:41 PM
  #37
Kids these days!........
Old Mar 19, 2013 | 03:26 PM
  #38
I am not buying zero fuel. You would no longer have exhaust pulses at that point from combustion events. I have never heard anything that would lead me to believe the car is using no fuel. Duals hide nothing
Old Mar 19, 2013 | 03:45 PM
  #39
Reject's Avatar
good ol 30mpg on the vette
i try to peg the rev limiter down shifting when coming to a stop, helps clear up the carbon build up
Old Mar 19, 2013 | 07:11 PM
  #40
Exidous's Avatar
DFCO can be turned off with a simple tune. I can validate zero fuel coasting off throttle. My W/B jumps to max AFR reading free air. The trans keeps everything spinning.
Leave the car in gear until about 1200rpm then press the clutch in and finish the stop. It's worth a full mpg if tuned right. It was for me.
