This Came Out of my Exhaust
I have had a rattle the past few days under car, and today I banged on my Cats to hear a rattle from them....I shot this out of a pipe too (Picture below)...its honeycomb looking. I assume obviously its from the Cat.
What am I looking at getting these replaced. I do my own work on cars, but I cannot do this.
Is there anything to watch out for when getting these replaced at shops, and has anyone had them replaced recently that might have a pricetag that I could compare to?
Thanks.
The stockers just bolt right in, BUT if you have a Cali type emissions car, which WERE shipped to the other 'Gestapo'-type states as well, the Magnaflows will not even do the trick as your ECM O2 sensor parameters are set to a MUCH more sensitive level as per the differences between the front and rear catcon readings.
In that case you will need a set of the actual CARB certified catcons (sometimes not even "50 state" ones will work) to keep the SES light off, and pass emissions.
Obviously, this is if one lives in an area with liberal inspection policy.
But sadly, in said 'commie' states they are trained to look for these as well during the visual.
