LQ9 vs L99 Water Pump pics
The Kwik bracket mounts to the water pump tensioner bosses. It is spaced for the truck depth (from the block to the top of the boss). It uses a completely different tensioner. TRhe mesurement comparison I need is the depth of the bosses on the water pump the tensioner bolts to.
Looking at the tensioers though, I'm guessing the depth of the bosses on the water pumps are different between truck and L99.
Here's a couple shots. The red pump is the LQ9 water pump, and it is the same pump that was in the first post here. I just painted it red for mockup to see if I wanted to paint the L99 pump to match the block.
The LQ9 was 1.50" from mounting surface to top of the boss and the L99 was 3.02" with the micrometer, but I just took a quick measurement it could have been 3.00" dead on. I couldn't hold everything in place and snap the photo, so I used a tape measure for quick reference.
LQ9:
![Name: WaterPump021x_zpsb6266461.jpg
Size: 58.6 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/609670d1501326017-lq9-vs-l99-water-pump-pics-waterpump021x_zpsb6266461.jpg)
L99:
LQ9:
L99:
![Name: WaterPump028x_zpsa44cf2d9.jpg
Size: 60.3 KB](https://ls1tech.com/forums/attachments/generation-iii-external-engine/609671d1501326017-lq9-vs-l99-water-pump-pics-waterpump028x_zpsa44cf2d9.jpg)
The following users liked this post:
Chuckitall (06-27-2019)
Just finished test fitting my front pulley system. L99 Camaro water pump with the Holley LS AC bracket because it has the factory cast aluminum look. Used the factory truck bracket with PS pump and Alternator that came with the motor. Below is some info on price and locations that I sourced this kit. The L99 water pump is a great fit if using truck acc and should make for a cleaner install for radiator hose routing in the Chevelle.
![](https://ls1tech.com/forums/attachments/generation-iii-external-engine/398561d1365741917-lq9-vs-l99-water-pump-pics-frontacc.jpg)
Rockauto.com
Water Pump ACDELCO Part # 251734 $162.00 delivered
Holley via Jegs price match with Team C Perfomace
510-21-3 INSTALL KIT LS LONG 82.23
510-20-134 A/C BRACKET PASS SIDE LS $120.42 + $13.99 Handling
Dirty Dingo
Truck LS Idler Pulley Relocation Bracket $28.99
Summit Racing for the new Idler Pulleys and Tensioner
DAC-89006IDLER PULLEY $12.83
DAC-89059IDLER PULLEY $14.89
DAC-89337BELT TENSIONER $43.79
Autozone
Serpentine Belt 6K1177 $32.00
Swapped PS pulley from Ford part# is E7UA 3D673 FB $7.00 Pick a Part
Rockauto.com
Dirty Dingo
Autozone
Application: ‘97 Corvette
Tensioner assembly with 68 mm grooved pulley
Holley part # 97-151
DAYCO # 89337
GM # 12559325
Rockauto.com
Dirty Dingo
Autozone
Rockauto.com
Dirty Dingo
Autozone
Thanks!
#33
#34
The later (07+) truck pumps with angle top port have the same block to threaded snout dimension as the earlier ones in post 22 above.
Its the spacing from the block that Im concerned with , Will the LS2 Truck water pump gain any clearance over the L99 , a 1/3 inch is not going to give me the distance I want from my radiator. It looks like the flater bell and being tighter to the housing it may work , but not sure how much the shaft sticks out.
