question about 5.3l head flow.
Old Mar 24, 2013 | 01:07 PM
KingPin1094's Avatar
Default question about 5.3l head flow.
I got these 5.3L heads for free, they have had some port work done. Im curious if anyone got these heads to flow ~320cfm? the best i have seen is ~300cfm. Just asking if it is possible, has it been done?
If not ill probably just sell them and get PRC stage 3 ls6 heads or 243 heads and have my head guy make them equal to PRC stage 3 ls6 heads.
Old Mar 24, 2013 | 01:21 PM
HCI2000SS's Avatar
Not sure about the flow, but for free i'd just go with it lol. I have those heads and they work pretty damn good for what they are...regardless on peak flow numbers
Old Mar 24, 2013 | 01:32 PM
well, i bought the car and it had 440whp. The car has a trashed bottom end so im going to build a forged 408. im shooting for 500whp. Im gonna redo the bottom end, install a different cam. I just dont think the heads will support my goals. but im not an expert so i created this post.
Old Mar 24, 2013 | 01:39 PM
Dragframe's Avatar
Your definitely going to need better heads...
Old Mar 24, 2013 | 02:15 PM
HCI2000SS's Avatar
Oh yeah if you want 500 rwhp I can see the need for better heads then lol
Old Mar 24, 2013 | 06:54 PM
garygnu's Avatar
stage 3 heads usually have big valves ment for 4" bores.most stage 1 heads are ported and have stock valves, and make 7 hp less.the tsp 5.3 ported heads are a good deal for the money.
Old Mar 24, 2013 | 07:06 PM
egod's Avatar
the 5.3s are nice units cause they have a smaller combustion chamber to increase CR, they can be ported to flow rather well too especially with a good valve job. But 500 rwhp would be much easier with higher flowing heads especially with a 4 inch bore, you would want heads/chambers designed for the bigger bore to give better flame travel
Old Mar 24, 2013 | 08:55 PM
Im starting to look into Ls3 heads, good idea?
Old Mar 24, 2013 | 09:20 PM
egod's Avatar
They will certainly have great flow numbers, but keep in mind that they have square ports so you will have to replace the intake and get a cam to match the flow numbers with respect to their lift. On a 408 you can go either way with cathedral ports or square. Although the ls3 has higher raw flow numbers, whats more important is air velocity which is what the cathedral ports are great at. There was an article in gm high tech, as long as the cam is matched correctly they performed almost the same. If you plan on going really big in the future the square bore will have more potential. But if you plan on staying under 700 HP then keep to the cathedral because the component cost is usually cheaper.
Old Mar 24, 2013 | 09:35 PM
I was planning on replacing the cam anyway, and i figured i could sell my FAST 92 for a ported LS3. Eventually (stress on eventually) id like to move to a twin turbo setup and make ridiculous power, but thats not of importance now. I was reading a thread from 2007 about l92 heads on a 408. It seemed then the major cam grinders were still trying to work out the best combo for the square port. Have we/most people/ the experts figured out what exactly suits the engines.
Old Mar 24, 2013 | 09:54 PM
egod's Avatar
If you plan on running boost then it would matter even less. But ultimately the higher flow number will have more potential. I would do it once and do it right if that is where you want to end up eventually. Do you plan on replacing the pistons later or are you build a low compression 408 from the get go?
Old Mar 24, 2013 | 10:15 PM
really my future plans are inconsequential to what im doing now, i may even change blocks then. Ive been doing some research and ive seen that the LS3 top end puts the power range a bit higher. And in my experience that would lower fuel economy. If i use 243 heads and get a higher LSA cam i could keep the power down a little lower and maybe get more mpg out of the car.
Old Mar 24, 2013 | 10:32 PM
egod's Avatar
it sounds like you already have your answer then. If your future plans aren't really a concern then stick with the cathedral ports and keep your intake.
Old Mar 24, 2013 | 10:39 PM
i think thats what i want to do, but i just wanted to research all aspects before i chose my path. see what will be best and do what im looking for.
