starter staying engaged after flexplate swap
Old Apr 5, 2013 | 05:32 PM
streetknight2's Avatar
Default starter staying engaged after flexplate swap
Changed transmissions from a th350 to a glide. While trans was out I put on a Hughes sfi flex plate. Now the starter Bendix stays out for 3-4 seconds after the car is cranked.
What can I check?
Old May 10, 2014 | 12:48 PM
6t7gto's Avatar
I have the same problem.
Did you ever solve this?
Old May 10, 2014 | 01:23 PM
No it still does it. What kind of flex plate are you using?
Old May 10, 2014 | 02:00 PM
Tbird232ci's Avatar
It's possible that you may need to shim the starter.
Old May 10, 2014 | 03:54 PM
6t7gto's Avatar
UPDATE: this is the flexplate I have.
the one that everybody recommends from Summit.
http://www.summitracing.com/parts/at.../applications/
I have tried shimming. I had about .120 of shims and it still does it.
Old May 11, 2014 | 05:57 AM
6t7gto's Avatar
I'm thinking of trying the dished flexplate that came with my 5.3.
Can I use the spacer, that came with the A270 flexplate, in back (toward the trans) of the factory dished flexplate?
Or do I need to purchase the adapter hub for my turbo 400?
Old May 11, 2014 | 10:11 AM
Gray86hatch's Avatar
How do you have it wired.
Also the Hughes flexplate I bought was bent out of the package.
Tim
Old May 11, 2014 | 12:28 PM
6t7gto's Avatar
I'm using a ford solenoid on the firewall.
Jumper wire on the starter from large battery terminal to solenoid switch terminal.
Old May 12, 2014 | 07:19 AM
My new engine is almost ready and I'm gonna try a different flex plate when it goes in
Old May 12, 2014 | 02:29 PM
6t7gto's Avatar
I had to change the 6.0 flexplate in my 08 van because it cracked.
I am going to pull the van starter and try it in my 5.3.
If it still hangs up, it has to be the A270 flexplate causing the problem.
The 5.3 is a 2001. I'm going to first check and make sure the 08 van starter is compatible.
I just checked advance auto parts site and it list two different part numbers for the different year starters.
Anybody know if my 08 6.0 starter will work in a 01 5.3?
Old May 12, 2014 | 04:19 PM
I tried 2 new starters since mine was under warranty. Tried shimming too. Also new solenoid. No luck. I've just dealt with it since mine's a track only car.
Keep us updated, hope you figure it out
Old May 12, 2014 | 04:39 PM
The 12v cable from the battery must go straight to the starter. Then run a signal wire from the Ford solenoid to the solenoid on the starter. A jumper on the starter will cause it to hang up in the flexplate.
Tim
Old May 12, 2014 | 05:36 PM
6t7gto's Avatar
I'll give that a try.
Old May 12, 2014 | 05:46 PM
6t7gto's Avatar
I found this...
http://www.s10racer.com/board/showthread.php?t=282
it states the late model starters will stay engaged using the jumper wire at the starter.
Like I have.
Gray86,
thanks for the tip.
Old May 13, 2014 | 09:42 AM
Originally Posted by 6t7gto
I found this...
Like I have.
Gray86,
thanks for the tip.
Sweet!!
Let us know if it fixes it and thanks for the heads up Tim
Old May 13, 2014 | 09:52 AM
Ford starters since the mid 80's have been like this. All ls stuff.
Tim
Old May 13, 2014 | 11:23 AM
6t7gto's Avatar
Wiring like gray86 said did the trick.
Thanks again.
Old May 13, 2014 | 04:55 PM
Thanks again.
Woohoo, I'll try mine tomorrow!
Old May 15, 2014 | 03:56 PM
Got it. Thanks guys! Man I was over complicating it. Been putting up with that mess for over a year
