EGR/AIR Removal
Old Apr 21, 2013 | 07:06 PM
CMURDAx's Avatar
Default EGR/AIR Removal
I see the sticky on the top there, but does anyone have links to pics that work so I know what Im looking for? Please and thank you in advance. Car is a 2000 Z28
Old Apr 22, 2013 | 04:10 AM
Burken01's Avatar
The tube behind your throttle body that bolts into the front of the intake (the 2" thick tube)
Unbolt it and buy a block off plate off eBay, done...
If you wanna get more complicated, you can go under the driver side car by the fender and unhook the air pump and the tubing that snakes all the way up to the intake which you removed earlier... But a lot of people just unhook the tube from the intake and leave the pump under the fender..
Old Apr 22, 2013 | 04:12 AM
Burken01's Avatar
Removing the pump only saves you 5 pounds or so in weight savings.. Hope this helps
Old Apr 22, 2013 | 06:12 PM
CMURDAx's Avatar
Is the AIR the tube that comes out of the lip and into a pump and then back up to the rear of the intake? And isnt there more EGR stuff hooked up to the exhaust?
Old Apr 22, 2013 | 06:15 PM
CMURDAx's Avatar
Sorry I havent really done much as far as removing stuff from a car before. Always got one with it previously removed so I never really seen what to take off
Old Apr 22, 2013 | 06:47 PM
Burken01's Avatar
heres a couple threads that go into detail with pics
https://ls1tech.com/forums/generatio...gr-delete.html
https://ls1tech.com/forums/generatio...de-w-pics.html
read those and let me know if you need more help, that should get you started
