Boiling water on intake manifold
Old Apr 23, 2004 | 01:13 PM
Classic Style's Avatar
Default Boiling water on intake manifold
Ok, when my engine is running, after about 5-7 minutes, water starts coming up at the middle "dimple" where the valvecover/head meeds the intake manifold. quite a bit of water is coming up there and its boiling. I am affraid I know what the problem is but I wanted to get some 2nd, 3rd opinions. Also, are there water passages that run through the intake manifold like on the old SBC?
Please help
Thanks
Edit - Also, the intake manifold/fuel rails are too hot to hold on to. Is this normal? This is actually the first time I have gotten my engine running since i got it outta the junk yard.
Old Apr 23, 2004 | 01:18 PM
2xLS1's Avatar
LS1s use a dry intake. No water passages at all.
Old Apr 23, 2004 | 01:22 PM
Cheatin' Chad's Avatar
No water through the intake.
do you have any pictures of this?
Old Apr 23, 2004 | 01:28 PM
So am I looking at a blown head gasket or craked head(S)? And sorry, no photos. Basically it looks the same as when there is a crack in a radiator and water is boiling out of it.
Old Apr 23, 2004 | 02:35 PM
zyal8r's Avatar
Sounds Like an Internally blown head gasket. Blown inside the cylinder around the combustion chamber.
Could also be cracked head.
Old Apr 23, 2004 | 06:57 PM
Danny2tek's Avatar
Old Apr 23, 2004 | 06:59 PM
Definitely could be a fracture in the head. I'd say it's time for some disassembly.
Old Apr 23, 2004 | 07:19 PM
FatZ28's Avatar
Im leaning towards blown head gasket beside the piston.
Old Apr 23, 2004 | 07:21 PM
cueball's Avatar
Please help
Thanks
could be blown head gasket, cracked head, or the coolant line the runs under the intake manifold, my coolant line was leaking, but i dont remember any coolant coming up through the chanles, but it would run down the front of the engine and filled the holes were the knock sensors are.
i just cut it out and sealed all four of the ports , and the radiator port off.
it is just there to warm the intake up, since it is a composit intake it dose not have any coolant running through it.
hope that helps, good luck
Old Apr 23, 2004 | 08:04 PM
2xLS1's Avatar
The coolant tube is there to bleed air out of the block and heads. Do not block it off.
Old Apr 24, 2004 | 12:52 AM
That was it! I had it plugged - amazingly enough.. it doesn't happen anymore. It seems weird to me that a gasket could re-seal itself after it was leaking. I'm just relieved. Thanks for the insight!
Old Apr 24, 2004 | 12:02 PM
cueball's Avatar
cool thanks, i did not know that it was also for air bleed off,
i guess it makes since.
thanks 2xls1.
can you block off the back ports and steel have the front ones hooked up
to the radiator,will that work?
Old Apr 24, 2004 | 12:13 PM
2xLS1's Avatar
That is the way all 01 and newer LS1/LS6 are set up. Plugs on the back and a pipe on the front. I believe there has been one person that said he blew a freeze plug out of the back of his head when he blocked off the pipe.
Old Apr 25, 2004 | 12:57 PM
just an update - I pulled the intake manifold last night, and cleaned out the massive amount of mud up there, and realized the water got stuck in the valley when I powerwashed the engine. I also found one of the valve-covers is cracked. So the water boiling up was just from extra water that never came out of the valley after a good cleaning.
Thanks for all the info!
