Hawks Sinister 4 inch exhaust?
Old May 16, 2013 | 07:23 PM
Grn4fbody's Avatar
Default Hawks Sinister 4 inch exhaust?
Anyone every ran one? How do you like it? How loud is it?
Old May 16, 2013 | 07:53 PM
Blackpanther99's Avatar
Check this out if you havent already... http://www.thirdgen.org/techboard/ex...r-exhaust.html
I have never listened to that exhaust soo I wouldnt know how loud or non loud it is. Hopefully someone comes in and helps you out.
Old May 16, 2013 | 11:43 PM
Grn4fbody's Avatar
Yeah thats where I saw it when I was trying to find a new exhaust system. Which I don't think that will be much different from what I have now (ORY and a Bullet)
Old May 17, 2013 | 01:34 AM
adamantium's Avatar
Looks like the mufflex system but cheaper.
http://www.hawksthirdgenparts.com/pr...stem-4%22.html
Old May 17, 2013 | 09:39 AM
US_Army_Z28's Avatar
The camaro they call sinister is owned by a guy that works at hawks, he custom made that exhaust for his car and everyone was so pleased with the reulsts he got they started making and selling the system, the system is loud, and I do mean loud, but it gives good results, and makes whatever it goes on sound plain nasty. There is a newer vidoe that hawks has on their YouTube channel of sinister on the dyno that'll give you a better sound clip
Old May 17, 2013 | 11:59 AM
Grn4fbody's Avatar
It can't be louder than my car with just a bullet and dumped.
Old May 17, 2013 | 04:18 PM
It probably isn't as loud but it probly isn't too terribly far from it either
Old May 17, 2013 | 05:44 PM
dailydriver's Avatar
I was considering that system for my car, but they will NEVER make it in 304 stainless, so I had Mufflex make me a stainless version in 3.5".
Old May 17, 2013 | 06:04 PM
Grn4fbody's Avatar
I thought the Mufflex systems were also aluminized pipe?
Old May 17, 2013 | 06:36 PM
SSellers's Avatar
What exactly are you looking for? Something quieter? Something louder? Something with tips? Hidden without tips? Something with more flow?
Old May 17, 2013 | 06:44 PM
Grn4fbody's Avatar
Something a bit quiter, hidden tips and isn't gonna rob a **** ton of HP
Old May 17, 2013 | 07:01 PM
SSellers's Avatar
OK. Check out the Dynomax Ultra Flo cat back if stainless isn't a necessity. It runs about $240 shipped after their $75 rebate. It's a single Ultra Flo bullet with 3" pipe all the way back to a 3" y with tips. You can position the y all the way up, cut off the tips, and put on turn downs hidden by the quarters. They also make their own offroad y to go with it although it's set up to also clamp to the standard 2-3/4" stock y as is.
I will not say that this will work, but just looking at mine....
This is kinda ugly when you get on the ground but...
You can see here that if you loosen the clamp on the left, the y will swing up another 3" and be pretty much hidden by the fuel tank.
Then what you have is instead of the setup below, the two tailpipes are up inside between the tank and inners. Angle as needed and put turndowns on them.
Old May 18, 2013 | 09:37 AM
The sinister system would cover all of this
Old May 18, 2013 | 09:57 AM
SmokedOutZ28's Avatar
I used there kit and just put a muffler in place of the straight pipe to keep it tame and quite.
Video Clip with Dynatech 4'' Race Muffler in place
Old May 18, 2013 | 11:23 AM
Grn4fbody's Avatar
How loud is that in the car?
Old May 19, 2013 | 09:05 AM
Wasent too loud at all during cruise the only issue I had was the drone at highway speeds.
Old May 21, 2013 | 05:20 PM
Most Mufflex systems are, but they DID build me a 304 stainless version once I requested it.
Others will NOT build a 304, 3.5"/4.0" single turndown system, for ANY cost.
