QTP e-cutout fuse keeps blowing
a limiting resistor inline so motor stall couldn't pop anything.
But that was at the business end of the harness, and even
if yours has a similar limiter, wire chafing and a short to
chassis could pop fuses easy.
I used a 10A circuit breaker, powered from my (20A?) power
seat feed, so no worries there even if something like that
happened.
I think the switch is your least likely point of failure, myself.
If the fuse pops in one direction but not the other, that
points to a single wire short (they alternate potential,
opening vs closing position, ground to ground short is
benign).
