bought hawk balancer tool have questions
What is your concern here?
I did it that way my first time and after that ati told me a trick and I don't ever torque the old bolt down anymore. Using a propane or map torch heat the BOTTOM of the pulley hub for a few mins then with oven mits just install it into the crank. It will literally fall on and you won't need to install the old bolt as you will feel the pulley bottom out on the crank. Then just follow the directions for the new bolt. If you don't have a torch 30 mins in a 225 degree oven works also.
After I had it on where I wanted it, I followed the instructions to put the new TTY bolt in (the 120* or whatever it was).
You can see a picture of what I'm referring to here: https://ls1tech.com/forums/17235917-post29.html
thats EXACTLY what im concerned with but thank you for the clarification i get it now! now can i position the pulley anyway or do i have to line it up with something?
