Exhaust Question
I did the install in my driveway, however I was replacing a Loudmouth system, so I can't comment on how hard it is to remove the factory system. I do know you'll most likely need to cut the I-pipe to remove it. I had to remove the spring and shock from my passenger side, and also drop the panhard bar, in order to get my SLP system out because the I-pipe was crushed together with a cheap clamp and I couldn't wiggle it out. You could probably do the same with the stock I-pipe??
