underdrive pulley question
Old Jun 22, 2013 | 04:00 PM
RobsZ28's Avatar
Default underdrive pulley question
Anyone notice inconsistent and or higher engine temperature after switching to a 25% under drive crank pulley? The engine in my car was rebuild everything is new including the cooling system it's a forged bottom end 11.1 347ci now. I had better and consistent coolant temperatures with a stock engine and a cracked leaking radiator.
Old Jun 22, 2013 | 04:21 PM
badazz81z28's Avatar
A high performance engine will make more heat, but it doesn't help when your water pump is spinning slower. I would expect some minor issues with a UDP. Higher engine temps be one in addition to charging issues and power steering functions. All that stuff is spinning slower with a UDP.
Old Jun 22, 2013 | 04:34 PM
Rich-L79's Avatar
I've noticed absolutely no changes in cooling or AC function after installing a 25% UDP on my LS2. It revs quicker though!
Old Jun 22, 2013 | 04:43 PM
spy2520's Avatar
It shouldn't make a huge difference. Unless you're idling for a long time.
Old Jun 24, 2013 | 03:18 PM
AmarilloWS6's Avatar
I had a Powerbond 25% underdrive pulley on my ws6 and never had issues, temps stayed the same, no flickering lights, etc. I now have a c5 with a Powerbond 25% underdrive pulley again and I still don't have any issues with anything. Both of my cars have been tuned with the pulley on as well so that may be part of the reasoning.
Old Jun 24, 2013 | 04:28 PM
dailydriver's Avatar
I know everyone on here swears by them, and I even had an ASP on the car for 12 years from buying it new, but I NEVER thought it was 'worth' the very few extra ponies it delivered vs. battery life, stop and go traffic cooling issues (shortening battery life even more from the fans constantly being on ), and a little rougher running due to less 'flywheel effect' balancer mass.
So, when that fell apart, I went with a FULL, OEM size Fluidampr to replace it.
Old Jun 24, 2013 | 04:36 PM
sopes's Avatar
I have heard so many mixed reviews, I think this winter I will get one. I dont plan on it idling for long periods but when I do that I will be getting a custom tune
Old Jun 24, 2013 | 06:20 PM
RobsZ28's Avatar
Thanks for the responses guys, so far the consensus is my problem isn't with the pulley. I am going to start looking someplace else for the problem.
Old Jun 24, 2013 | 07:14 PM
sopes's Avatar
Is it a stock water pump ? stock t-stat ? manual or auto trans ? ever blew out the heater core ?
