Questions on 5.3 build.
Old Aug 22, 2013 | 12:37 AM
Redchevyman's Avatar
I found out that Chevrolet Performance advertised the wrong bolts with the spacer. I found the right bolts that are 3/16" longer at the local dealer. 19257940 is the part# for those of you that are having the same issue.
Old Aug 23, 2013 | 03:24 PM
I plan on dropping the engine in tomorrow. Hopefully it will start.
Old Aug 29, 2013 | 11:49 AM
What brand and weight motor oil do you guys like in a 130,000 mile 5.3?
Old Oct 30, 2013 | 07:53 PM
How do you get your power steering pump hooked up to a 1974 Chevy power steering box? Is there an adapter to go from SAE to metric? Or a conversion hose available?
Thanks
Old Nov 1, 2013 | 08:14 PM
I ended up cutting the end off of the tube and put a new SAE nut and flared it. Hopefully the 5.3 pump is compatible with the 74 Camaro steering box.
