Doing Header Install: Do I need a cherry picker?
Old Jun 27, 2013 | 11:45 AM
idle's Avatar
Default Doing Header Install: Do I need a cherry picker?
I plan on taking on this endeavor in my apartment garage, facing inwards (towards the back, away from the garage door). Will I need to have a cherry picker to lift up the motor so I can replace the motor mounts and/or do the headers? I plan on doing the following:
*Headers (duh)
*Motor Mounts (poly's)
*Spark Plugs & Wires
I have 2 floor jacks and a car jack. Just not sure on jacking points of the motor itself. I already know I have to have the car higher than Lil Wayne on April 20th...
Old Jun 27, 2013 | 12:02 PM
LS-ONE_DAY's Avatar
Pretty sure you will need one if you're doing motor mounts. We used an engine hoist on mine and it was a pain in the *** because when we lifted it up it was being lifted slightly off center and it twisted the motor a fraction of an inch and we couldn't get the damn motor mounts lined up.
Old Jun 27, 2013 | 12:38 PM
BIG_MIKE2005's Avatar
You can do it all without one. a little searching on here & you'll find a few ways to go about the motor mount swap. For the headers & plugs all you need is to jack the car up high enough to get the LT's in from below.
Old Jun 27, 2013 | 01:17 PM
idle's Avatar
Thank you!
Old Jun 27, 2013 | 06:19 PM
nj02z's Avatar
For the motor mounts,put a jack with a piece of wood(2x10) under the oil pan and remove the entire pedestal . Do one side at a time. It is much easier this way.
Old Jun 28, 2013 | 01:40 AM
xxrillixx's Avatar
I like using the cherry picker for the motor mounts.
Old Jun 28, 2013 | 12:11 PM
spy2520's Avatar
I did solid mounts and long tubes without a hoist, just floor jacks. Later, i did a converter and i have to admit dropping a trans with solid mounts is the most/least fun i've ever had working on a car.
Old Jun 28, 2013 | 04:41 PM
xxrillixx's Avatar
Thats no joke. Solid mounts have NO GIVE. Even polys make it tough, but its do-able.
Old Jun 29, 2013 | 02:06 AM
AmarilloWS6's Avatar
I did mine in my garage with jack stands and a jack. Just put a piece of wood on the oil pan and jacked the motor up a bit to keep it in place. One thing I didn't have an issue with though is the motor mounts lining up like everyone else does on here, I got the bolt halfway in before it stopped, so I just tapped it with a hammer and it slid all the way through on both sides. Good Luck!
Old Jun 30, 2013 | 09:33 AM
cyberkill's Avatar
https://ls1tech.com/forums/generatio...otsa-pics.html
Check out section 5, I also used a jack below the motor.
Old Jun 30, 2013 | 04:08 PM
VandykeT/A's Avatar
You don't need one. I did mine with jackstands and floor jacks. Just use a piece of wood and jack it up like has been said. And definitely remove pedestals. Makes it a ton easier to line up. Also pay attention to how the mounts go in the clamshell. I ended up having to do one side twice lol.
