Need a cam that makes good torque down low
Old Jun 29, 2013 | 11:39 AM
kainedogg's Avatar
Default Need a cam that makes good torque down low
I grow weary of my Texas Speed cam Texas Speed Torquer V2 232/234 .595"/.598" Camshaft. Apart from my 3000 stall converter, everyone says go with 3.73's but I like my highway gears.
What cam is great for torque and low speed drivability? I assume something with a sub 22* duration and will work with the trusty...or not so trusty 4l60e and 3.15 gears.
Old Jun 29, 2013 | 11:54 AM
moeZ28's Avatar
3.15?? Stock is 3.23 or 2.73 for autos...cant go wrong with the off the shelf comp 224/230...very nice little cam. Great low and midrange power, just big enough to keep a little top end. Seen a few around here do awesome. One of my friends runs that cam in a stock lq4 with 243 heads and runs mid 10's in the 1/4. His car only weighs 3000 lbs though.
Old Jun 29, 2013 | 12:27 PM
trans_am7935's Avatar
i have a Comp Cams 227/235 and i have excellent driveability. i can cruise at 1100rpms in 5th on the street, not advisable but still able too. i usually shift right around 2k when driving on the street. very usable power from 1500-2000 rpms
Old Jun 29, 2013 | 01:19 PM
99Bluz28's Avatar
So what's the lsa on your Trq V2..?
Tick Performance "SNS" torqueMAX Stage 1 Camshaft (3* 0verlap)
http://www.tickperformance.com/tick-...1-ls6-engines/
or go custom and get a 223(lsl)/226(lxl) 110+0 (4.5* overlap) .
Old Jun 29, 2013 | 01:32 PM
D14HUGGER.ORANGE's Avatar
Comp cam 223/231 610-617 112 lsa. I'm running one on my 99ss. Nice choppy idle street friendly, I put down over 400rwhp with full bolt ons h/c/I. I bet that comp 227/235 ^ would be a good one too.
Old Jul 1, 2013 | 02:21 PM
thunderstruck507's Avatar
Put a decent converter in the car instead of changing the cam/tune IMO.
Old Jul 1, 2013 | 02:29 PM
JakeFusion's Avatar
Super Hulk Smash
3000 is too low for that cam. Needs a 3600 minimum.
If you don't want to do that, swap to something with an IVC of around 42 degrees. Also, I'd stay under 8 degrees of overlap for good street manners. So you have the following options that meet those criteria:
227/230 110+1 (LSL/LXL)
226/230 110+1 (LXL/LXL)
227/231 111+1 (LSL/LSL)
Futral also has a grind that would work well:
F11 - 228/232 112+4
Old Jul 1, 2013 | 08:26 PM
kainedogg's Avatar
Thanks guys. I forgot to mention that the car is a '98 C5. I am going to bite the bullet and get a 10" 3600 stall and see what happens. The LSA now is 113.
Old Jul 2, 2013 | 12:28 AM
JakeFusion's Avatar
Super Hulk Smash
LSA only adjusts the overlap for a given duration. The valve events are determined by the duration + LSA. If you noticed, to get the IVC of 42 and an overlap that was healthy, it ends up with similar cam specs.
Old Jul 2, 2013 | 08:25 PM
garygnu's Avatar
a better matched converter should do much better .
Old Jul 3, 2013 | 06:47 PM
kainedogg's Avatar
Forgive my ignorance but why? How would a higher stall make the car anymore fun to drive at part throttle? Sounds like more slipping but with a nasty hit when you floor it.
Old Jul 5, 2013 | 09:20 AM
if you REALLY want to pick up low-mid range feel, pull the heads and have them milled for more compression
gears would also help but you don't want to change them...
I would expect to get the results you want by swapping cams you will need a fairly drastic change. You will also have to have the car retuned for the new cam.
Old Jul 8, 2013 | 08:18 AM
kainedogg's Avatar
Heads are already shaved & I am stepping up to 3.42's. still not understanding the higher stall for drivability
Old Jul 8, 2013 | 08:50 AM
VandykeT/A's Avatar
The torque converter won't make much difference in driveability. Its just going to give you more low and midrange from the extra rpm.
