LS6 valley cover conversion - what's this part?!?
I did the LS1 to LS6 valley cover today. I also installed a new OPSU to hopefully stop a pesky oil leak. Also did new knock sensors and the wiring harness. Everything has gone good so far and I'm letting the intake dry overnight (soaked it in dish detergent and purple power to remove the oil and gunk inside). I removed the fuel rails and the sensor on the back of the intake manifold before i soaked it (duh). Also removed the purge solenoid.
However, as I'm cleaning up, I see this clip-like button thing underneath the car on the pavement kinda on the driver's side right behind the k-member. It's plastic except for the part underneath the button part which is metal. Pics are attached. Anyone know what the hell it is? Thanks!
if you looks at the one on the left you can see "the button" sticking out the white part
another example
http://i21.photobucket.com/albums/b2...z/100_3565.jpg
