LsX Intake Issues In Terms of Tuning??
Old Apr 28, 2004 | 11:29 AM
SilverGhost's Avatar
Motorboater
Default LsX Intake Issues In Terms of Tuning??
Well I'm having a buttload of issues with my car right now that are keeping it from running right, making power, and being dyno tuned.
I have been going through the car with a fine toothed comb and am trying to nail it down. I am basically going and putting back any changes I nade since October when the car ran well right after I put my new motor in.
Only thing left really is the LsX intake vs the Ls6 i had on before.
What I'm looking for is any experiences from others that put this intake on and had things come up..what did your car do if anything i.e--lean way out, go way rich? Any other problems like that. My car is running very fat and can't be leaned out until I can get everythign to behave itself so it can be properly tuned. I have lsX intake, custom 78mm ported Tb, stock MAF with screen.
Any experiences/challenges from other LsX users would be appreciated, as I just need more ideas here.
I may stick a bone stock LS1 intake on it this weekend to see what happens and see if they LsX is to blame at all.
Old Apr 28, 2004 | 11:32 AM
Fireball's Avatar
mine seemed pretty dead on using a descreened 85mm SLP maf (with cal resistor cut out) and the descreened 85mm MAF tables I found on here
I'm running the 90mm LSX and TPIS 90mm TB
Old Apr 28, 2004 | 11:35 AM
Slowhawk's Avatar
LS1Tech Sponsor
I haven't had any problems with the last 6 I installed.Tuning needed minor richening.
Old Apr 28, 2004 | 11:51 AM
Zero2Sixty's Avatar
I'd say do it, it doesnt take that long to make a swap.
Old Apr 28, 2004 | 12:02 PM
Motorboater
yeah i think it'll be worth the 20 min of my time as well so i'm gonna try it.
i dunno, the car is all goofed up right now, just trying to get it figured out
Old Apr 28, 2004 | 01:16 PM
CamaroSS_2002's Avatar
understand if your intake isn't sealing for some reason that can be your who problem and you may not be able to hear the leak. Also check your MAF, a maf can fail -- it doesn't happen often but it can I suggest before you go to too much trouble you borrow someones known to be good STOCK maf and see how it performs.
Old Apr 28, 2004 | 01:18 PM
Motorboater
as mentioned in my post the maf is bonestock, right down to the screen. i got rid of the ported one so i could have the car tuned properly.
i've done all i can to eliminate a vacuum leak possibility, there is no way its leaking to the best of my knowledge/experience, but i'm still afraid there might be something up with the intake and its leaking somewhere..putting a stock one on should clarify that
Old Apr 28, 2004 | 01:49 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Um didn't you port your LSX and break through? Just what I heard.
Old Apr 28, 2004 | 02:07 PM
Motorboater
nope, did not break through, all i did was open it up to match my heads.
Old Apr 28, 2004 | 04:01 PM
chpmnsws6's Avatar
ummmmmm.... boss man's spreading rumors.....
