Wrong Metal for SLP LM1
Even says right in the description stainless steel: SLP LM1
<<X-stainless welder.
Thanks, I follow what was said. The grade of metal is definitely different than my old LM1. A magnet will not stick to my current LM1 but will on the new one. The metal is also a different shade. On the exhaust it says 409 aluminized, which after doing some research I guess it is stainless steel. I also see that 409 aluminized stainless steel is just stainless steel dipped in aluminum. However, as I said the new system is different from the old one. The old one actually looks much nicer as it has a nice shine to it. The new one is dull like the Corvette's x-pipe is from the factory. I guess I was expecting it to be like my current LM1 but got something different.
Pictures:
As far as I know ALL of Magnaflow's systems and mufflers are 409 stainless, except for their tips which are 304.
The new LM1 was the aluminized version which and was visually different from my original LM1 (dull on the new one vs shiny on the original). I too did the magnet test...didn't stick to the original but did to the new one. I finally got a confirmation from SLP that they did change the material they use to make the exhaust. It is still "stainless steel", but as had been said by others, it is a different grade that is also aluminized. I forget the specifics, but grade 409 sounds familiar.
Ultimately it's under the car so I don't mind too much and it still sounds awesome.
From Dave Hamburger @ SLP:
"The piping is still stainless, it's been given an aluminizing process that helps brighten the finish and keep it brighter longer."
I then asked if the pipes could be polished to look like the original design and received this response:
"If you polish the AL stainless, you'll polish the AL off of the tubes. Brasso should keep the pipes looking like new."
From Brandon @ Maryland speed:
"SLP does not have any plain steel at their facility. The exhaust you received is 409 stainless. 409 stainless is a lower grade of stainless that many exhaust manufactures use (Magnaflow, Bassani, etc). It has more iron in it than say 304 stainless, so it is magnetic. 409 stainless may develop surface rust, but it will not rust through. The AL from what I understand does mean it is aluminized..but it is aluminized 409 stainless, not plain steel."
ALL but the very top tier, crazy expensive exhaust companies (Corsa, Kooks, B&B, Borla<-not even ALL of these anymore either)
use 409 now, and NEVER 304, sad as that may be. The only exceptions seem to be that some of the less costly systems for the y bodies are still all 304, as I guess they feel that they "deserve" the austenitic stuff more than us 'lowly' f body owners do?
Keep in mind, SLP was sold in May and moved to Michigan, so the metal is likely coming from a different mill, which is why it looks different.
http://www.slponline.com/product/310...Dual-Tips.html
