Question about 85mm MAF?
Z06 or truck MAF, rich; screw it lean with a GMAF.
Two wrongs don't make a right, generally speaking,
but that doesn't stop people from trying.
It's also quite untrue that you gain nothing from
an 85mm MAF and a 70mm TB. Air is a compressible
fluid, not like you're trying to cram an 80mm marble
down it and it'll get stuck or something.
But, whether you'd gain enough to be worth the grief
is another matter. You will need to either solder-tune
a Z06 (or truck) unit, or righteous-tune the tables in
the PCM. Only the latter will have a chance of getting
you right across-the-board, though the former may
get you "good enough" - but even there you'd need at
least scanning capability.
