Thermostat Housing
Old Jul 24, 2013 | 09:51 PM
jaywill's Avatar
Default Thermostat Housing
is this the wrong Housing 4 04 5.3? 160 stat won't fit wft !!!
Old Jul 24, 2013 | 10:50 PM
nomasterase's Avatar
Looks more like the wrong t-stat. It should have two tabs opposite of each other that lock into those legs on the housing
Old Jul 25, 2013 | 03:21 AM
jaywill's Avatar
On the thermostat said for a LQ & LM 7 ENGINES
Old Jul 25, 2013 | 10:12 AM
joecar's Avatar
The housing you show is for GenIII (requires a GenIII TS (has ears that mate to those tangs)).
The TS you show is for GenIV (requires a GenIV housing (has no ears, and no harness post)).
Also note that a GenIII housing will not fit into a GenIV pump (unless you file the tangs for clearance).
Old Jul 25, 2013 | 10:29 AM
joecar's Avatar
Look at these:
https://ls1tech.com/forums/generatio...anability.html
https://ls1tech.com/forums/generatio...t-housing.html
https://ls1tech.com/forums/generatio...n-correct.html
Old Jul 26, 2013 | 03:30 AM
jaywill's Avatar
i have the wrong housing for my 04 engine !
Old Jul 30, 2013 | 08:28 PM
jaywill's Avatar
Where can I get a 2 piece housing ?
Old Jul 31, 2013 | 10:21 AM
joecar's Avatar
From GM.
Old Jul 31, 2013 | 01:07 PM
jaywill's Avatar
i just did the bb mod on my stock Tstat..
Old Jul 31, 2013 | 01:31 PM
1fastpickup's Avatar
I just went through the same thing. GM has two pumps, the replacement pump has the two piece t-stat.
P/N for the two piece housing is 12600172 local dealer wanted $61
Old Jul 31, 2013 | 07:23 PM
joecar's Avatar
Then file the outside of the ears on your housing so it fits all the way into the 2004+ pump.
edit: reworded.
Old Jul 31, 2013 | 08:11 PM
jaywill's Avatar
Originally Posted by joecar
Then file the outside of the ears on your housing so it fits all the way into the new pump.
i have a old pump...
Old Jul 31, 2013 | 11:04 PM
joecar's Avatar
Reworded post #11.
Old Aug 2, 2013 | 04:26 PM
joecar's Avatar
Do you have old-style pump and old-style TS/housing...?
Does your housing fit into the pump...?
If it doesn't (ears of housing interfere on size of bore in pump) then you have the new-style pump.
Old Aug 3, 2013 | 06:45 AM
jaywill's Avatar
do you have old-style pump and old-style ts/housing...?
yes..
