Casper 3-5 wire MAF wire harness
Old Jul 30, 2013 | 12:59 AM
man2004's Avatar
Default Casper 3-5 wire MAF wire harness
I have a 99 TA Heads, Cam, bolt-ons with a stock MAF and SLP air lid with AIT already drilled into in the lid. Before the final dyno tune, I want to install a de-screened SLP MAF and keep the AIT in the lid to prevent heat soak. Do I need the Casper 105591 3 to 5 wire - no pigtail? Or, the Casper 108100 3 to 5 with pigtail? I read several threads and I am a little confused. It is almost counter intuitive. I am guessing if I want to retain the AIT in the SLP lid and not use the built-in AIT in the SLP MAF, I need the 105591 (no pigtail). Correct?
Old Jul 30, 2013 | 09:17 AM
thunderstruck507's Avatar
To answer your question, you want the 3 wire to 5 wire adapter harness without IAT so you can use stock IAT harness and sensor. Search ebay for "5 WIRE MAF TO LS1 3 WIRE HARNESS ADAPTER".
I will add that if you are going to do this prior to a tune anyway, get the GM MAF and not the SLP.
Old Jul 30, 2013 | 09:27 AM
alexus6798's Avatar
That's what I did. I kept my IAT sensor in the lid but I cant for the life of me remember the part number for the adapters. I'm trying to go back through my ebay history and find it though. Will report back once I do.
Old Jul 30, 2013 | 09:39 AM
alexus6798's Avatar
Found it. This is the one I got
http://www.ebay.com/itm/5-WIRE-MAF-LS1-3-WIRE-HARNESS-ADAPTER-/250960779906?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item3a6e6d9a82
Old Jul 30, 2013 | 06:34 PM
man2004's Avatar
5 Wire MAF to LS1 3 Wire Harness Adapter | eBay
Excellent!!! That looks like the Casper 105591. Thank you!!!
Old Aug 10, 2013 | 07:37 AM
JimMueller's Avatar
Has anyone already bought this? The adapter which came with my TSP 100mm MAF years ago had a pair of wires reversed. I'm troubleshooting a MAF problem and was considering replacing the adapter, but I'd rather the wiring be correct when received.
Old Aug 10, 2013 | 08:27 AM
alexus6798's Avatar
I have it and haven't had any issues with it at all.
Old May 5, 2014 | 11:30 PM
Mr. Trick's Avatar
Sorry to bring up an old thread but is there a reason to keep the IAT sensor in the lid vs using the one in the MAF?
Old May 6, 2014 | 08:25 AM
ssgunny's Avatar
According to the OP it's to prevent "heat soak." Not that I don't understand his concern but it's the first time I have heard that term associated with the IAT.
Old May 6, 2014 | 10:01 AM
The maf housing is metal and closer to the engine than the plastic lid. Not sure how much of an issue it really is, but I could see the internal MAF giving higher IAT than a lid mounted IAT.
Old May 6, 2014 | 06:23 PM
Mr. Trick's Avatar
Will this harness work with a truck/Z06 LS6 maf or only for LS2 maf? Or is it all the same
Old May 7, 2014 | 09:09 AM
they should be the same (or at least they have been on the cars you mention I have worked on)
