FAST 92 Porting Job Gone Wrong?
Old Aug 1, 2013 | 10:17 PM
Qfly's Avatar
Default FAST 92 Porting Job Gone Wrong?
After reading about port matching, I decided to grab my ported FAST 92 and give the runners a closer inspection and found the following.
Exposed gasket on the front drivers side...
Exposed gasket on the rear passenger side..
Since I do not want to take any chances, I have also sent an e-mail requesting a RMA and shipping label to send this one back for a replacement What do you guys think?
This is one of those "if it doesn't look right or feel right, speak up or don't do it!"
Well, I am speaking up and not doing it
Cheers,
Q
Old Aug 1, 2013 | 10:42 PM
therabidweasel's Avatar
IMO if you paid 200 you got what you paid for. If you paid 500 you should make one hell of a fuss. I doubt it will make any difference at all in performance and should not be a leak. ..but you cant expect perfection in hand work if you go cheap. It just takes too much time, skill, and materials to make it perfect.
Old Aug 1, 2013 | 10:53 PM
Qfly's Avatar
See my signature I did not think I was going with a cheap port job.. I would make one hell of a fuss if the port job cost 200 or 500 bucks: money does not yet grow on trees
Q
Old Aug 1, 2013 | 10:59 PM
427zm's Avatar
I'm sure vengeance will make it right.
Old Aug 1, 2013 | 11:06 PM
Qfly's Avatar
Yup, they are good dudes and I am not too worried about it.. Basically, give your ported runners a good once over before you install..
Q
Old Aug 2, 2013 | 08:38 AM
thunderstruck507's Avatar
It doesn't matter if it was $200 or $800. If you **** up what you were working on you fix it.
Basic porting on these intakes is not ******* difficult and $200 is way more than fair for the basic porting most people do on them.
Old Aug 2, 2013 | 01:20 PM
Qfly's Avatar
Everything is taken care of now...
Return label has been issued and a new intake is being ported for me. Now thats great customer service!
Cheers,
Q
Old Aug 3, 2013 | 08:04 PM
VIPERBLUELX's Avatar
How is that not caught before its shipped out?
Old Aug 4, 2013 | 05:46 PM
1320Chicken's Avatar
Probably an "Oh ****! Lets see if anyone notices" kind of deal. I don't see how the guy that did the work could miss orange gasket material peeking through a black runner. Lets face it, that a $1000 mistake.
Thunder is 100% right. Price means nothing. If you are going to do anything you should take enough pride to do it right. They set the price after all.
In the end it doesn't matter since vengance is making it right. No doubt in my mind there are vendors that would just tell you to run it, and it shouldn't leak.
Old Nov 14, 2013 | 12:35 AM
m_birzer's Avatar
I just received my ported fast 92 and found the same thing in two of the runners. Is this a major issue or bad port job? I'm gonna contact vengeance to try and get more info.. I hope I don't have to wait even longer to install my setup.
Old Nov 14, 2013 | 11:47 AM
m_birzer's Avatar
Kevin at vengeance told me it is perfectly fine and it's normal. Mine looks almost identical to the pics you posted here..
Old Nov 14, 2013 | 11:51 AM
KCS's Avatar
KCS
Moderator
That's what I was thinkining. I don't really see a problem unless the gasket was missing.
Old Nov 14, 2013 | 08:31 PM
badassracing's Avatar
I dont see where it would be an issue. Thats some nasty looking port work though....I'd be pissed if I paid for a ported intake and thats what I got.
Old Nov 15, 2013 | 08:26 AM
Marc 85Z28's Avatar
If it's normal why doesn't my Vengeance ported 92mm look anything like that? Charlie did mine in early 2008.
Old Nov 15, 2013 | 09:28 AM
Zmg00camaross's Avatar
I ported mine it doesn't look like that. But I still suck at porting haha.
Old Nov 16, 2013 | 12:24 AM
99Bluz28's Avatar
Those two opposite runners have a larger bump/ridge in them, as a result its easier to end-up taking grinding off to much material to smooth it.
I ended up doing the same thing on those two runners, but not quite that much and I didn't damage the rubber seal. All I did was dab some RTV sealant into the two spot I broke through and I've had no issues at all.
http://i136.photobucket.com/albums/q...S/1000Grit.jpg
