Who makes an engine torque strap?
Old Apr 30, 2004 | 03:03 PM
Redlinez's Avatar
Default Who makes an engine torque strap?
Thinking I need to install a driver side poly engine mount but was wondering if someone has devised an engine torque "strap". I've seen nice billet straps with rod ends on other cars, so I was just wondering about this. I'm sure I could have one fabbed, but would rather find one made.
Old Apr 30, 2004 | 05:28 PM
WILWAXU's Avatar
I use a motorcycle strap from Home Depot.
Old Apr 30, 2004 | 06:53 PM
FAST LS1's Avatar
I went to Lowes and bought a ratchet strap that looks like this.
I then looped it like everyone else did around the alt bracket and secured it to the k-member. I've had it on for at least a year and it's worked fine at keeping the y-pipe from banging.
Old Apr 30, 2004 | 07:12 PM
Redlinez's Avatar
Sweet!!! I may just try that. Home Depot is around the corner!!!! Much cheaper and quicker fix.
Old May 1, 2004 | 12:20 PM
Redlinez's Avatar
How cool would it look to have a billet engine brace going from the passenger front of cylinder head to strut/shock tower? Wonder if anyone makes anything like that? For now, if it's good enough for Wilwaxu, it's good enough for me, even though someone on our local board called it ghetto. I don't mind being that it's far from a show car.
Old May 1, 2004 | 02:34 PM
boondiggys's Avatar
get one of those adjustable eye hook things bolt one end to block other to frame once bolted can turn the housing one way or anther to tighten it up
Old May 2, 2004 | 09:12 AM
WILWAXU's Avatar
You risk false knock retard if you mount anything solid between the motor and the chassis. That's why the strap works well.
Old May 2, 2004 | 10:38 AM
jerflash's Avatar
does anyone have a picture of how and where this straps on the car?
thanks
Old May 2, 2004 | 12:39 PM
Redlinez's Avatar
Just went to super Walmart and got a pair. $13.87 1500lb rating, 500 work capacity I believe. Time to jack up the Z.
Old May 2, 2004 | 03:49 PM
Demon SS's Avatar
You could always use Spohn soild motor mounts but then you need to disable the knock sensors.
Old May 3, 2004 | 05:23 AM
Redlinez's Avatar
That already tells me what that would sound like, mine is a daily, so I couldn't take it I'm sure.
Old May 3, 2004 | 10:13 AM
Hawkn01's Avatar
I have mine solid mounted and no knock retard. The mounting points are isolated with firm rubber. I use an aluminum adjustable turn buckle mounted at the head and it runs down to a bracket I fabbed up on the frame. It's worked like a champ.
Old May 3, 2004 | 12:26 PM
boondiggys's Avatar
yesss turnbuckle was the word!!
Old May 5, 2004 | 07:41 PM
Kent1's Avatar
Could somebody explain the purpose of this mod on the car? Does it give you more torque or takeoff for launch. Your assistance in explanation would be appreciated.........
Old May 5, 2004 | 08:30 PM
WILWAXU's Avatar
Theory is that you loose hp in the movement of the motor. limiting it's movement helps re-capture some of that.
Old May 5, 2004 | 10:10 PM
Kent1's Avatar
Thanks Wilwaxu................
Old May 5, 2004 | 11:41 PM
Jeffs99SS's Avatar
Funny, just a couple days ago I started thinking of a torque strap. I am still getting some y-pipe banging, even with a custom y. I was just not looking forward toward the labor involved in a poly motor mount. I may have to make the trip to Home Depot myself.
Jeff
