Finally Spending $ on Kooks LT+TD
as far as exhaust install, it shouldn't be too bad since you went with Kooks, but as it's been said - take your time, get the car up at least a couple feet off the ground, use penetrant where necessary before you begin, new OEM header gaskets, be very careful when re-installing the header bolts, apply anti-seize to header bolts and spark plug threads, but make sure the threads in the cyl head and the header bolt are clean as you can easily damage the threads in the cyl head (trust me lol)...if your picky like me, ARP makes a nice set of stainless header bolts for LS aluminum heads in hex or 12 point (just looks a little prettier than the originals)...I bet that Kooks duals setup is a handful to install, but given the quality, it probably won't be too bad...you get what you pay for!...you'll love your new-found power & sound
I would caution against using Acetone in any enclosed space. I used to work in a plant that used it by the 50 gal drums to clean parts prior to shipment and I seen one person that had some serious problems with it.
Also, I'm not sure how hard PHB bolts usually are to get out but I sprayed everything down with the ATF/Acetone solution 30 minutes before starting and all of them came out with minimal effort.
Can someone please tell me which bolts I will need to order and also if the pictures below are the correct mounting location? Thanks!
I have the same exhaust and car color as you! You will love this exhaust, the install is kind of hard, but getting it to fit perfect is the only 'pain'.
As for the safety loop....you don't NEED one so I wouldn't put it on. Return that BMR piece and buy some sub frame connectors.
Got the DSL installed today. Ended up having to grind off a plate that was welded over top of the tunnel brace mount. I'm guessing the previous owner must have had weld-in SFCs/DSL. Also, the flange bolts I orderd for the DSL worked perfectly with the addition of a washer.
In a slightly unrelated note, I installed Koni Shocks/Strano Springs that I bought used from a member on here. It seems a lot lower to me so I'll be sure to let everyone know how good the Kooks fit with a lowered car.
Motor mount installation will begin tomorrow now that I got my other car back. Sister's car was wrecked and she was my borrowing my usual DD and so I couldn't start because of that.
Video of my current Magnaflow catback for comparison once I get everything on:
I also have a lowered TA. So clearance was always a concern of mine. Hope you keep us posted because this will be very helpful to me. My car is lowered enough that once the front end is on jack stands I gotta put my jack under the car and jack up the rear from the axle. Had to buy a really low profile jack with an extended base.
Really looking forward to your finished project and or the bumps in the road.
GL
Good news, the only thing I've broken so far (that I know of) is a coolant sensor.
In for a video.
Question about the kooks system, do they come with a muffler or is it going to be straight pipe?
Question, is it normal for the headers to smoke a little on first start up? I made sure there was no wires or anything touching the headers but I just wanted to make sure it wasn't my gaskets that were leaking. Kind of a funky oil burning smell.
