Making my own lid....
Old Aug 11, 2013 | 02:56 PM
kpadlina's Avatar
Default Making my own lid....
since I can't find the spectacle solutions air intake lid for cars with vortech s/c on them I'm forced to make my own....
my question to everyone is... does anyone have one I can take measurements off of? does height play a huge factor on performance?
I will be making a lid out of stainless steel and continue piping all the way to the charger and deleting the MAF as well.
some feedback would be greatly appreciated since i'm going into this almost blind.
Old Aug 11, 2013 | 04:33 PM
studderin's Avatar
I made mine out of alum. easier to work with. I have a sunoco hood so have some more room to make it taller. Thats what I needing for running taller intakes, and to point it at the TB better.
what hood do you have? I made it out of carboard 1st and profiled the front and back the the hood, so its only touching to 1/8 away. Think I took the rad out, and or the fans, the WP, air dam, and my lower ducting going to the bottem of the lid. and put back the lower airbox and crawled up behind the rad. in front of the motor with a light and marked the templets as trimming them.
I made the base of the lid with alum angle iron to make the square frame, used a bridgeport to profile the front part to the stock lower one, (copied my SLP lid) and were the clips go. welded tabs on the back were it slids in. And sheet metal the sides and top off that. I would use do it that way again, make the square frame and work off that.
posted pics in my build thread
Old Aug 11, 2013 | 04:51 PM
kpadlina's Avatar
can you post a link to the build thread? I can't seem to find it. thanks.
Old Aug 11, 2013 | 04:59 PM
studderin's Avatar
https://ls1tech.com/forums/drag-raci...h-diet-44.html
https://ls1tech.com/forums/generatio...-cold-air.html
