Solid Motor Mounts and Vibration
Old May 1, 2004 | 12:57 AM
Gold Phoenix's Avatar
Default Solid Motor Mounts and Vibration
How much more vibration is there with solid motor mounts on a street driven car? Would it be too annoying?
Old May 1, 2004 | 01:56 AM
boondiggys's Avatar
i dont have them but i would think it would be very noticable steering wheel making hands go numb ha just get some urathane ones and ull be goood
Old May 1, 2004 | 07:34 AM
WILWAXU's Avatar
solid motor mounts = Lots of knock retard.
Go for a set of poly mounts.
Old May 1, 2004 | 03:10 PM
383LQ4SS's Avatar
I used poly mounts recently. They are awesome. Very little movement...but not solid.
I used to dyno with the stock mounts....when the second stage hit the motor would practically roll over and touch the fender. At idle the exhaust was always hitting and vibrating. Now with the polys there is VERY little movement.
Old May 2, 2004 | 10:43 AM
How would solid motor mount cause knock retard? The movement of the motor is transfered to the chassis without anything hammering each other. I have heard problems with solid lifters causing knock retard because the lash sounds like minor knock.
Old May 2, 2004 | 11:46 AM
KGSloan's Avatar
i'm not sure exactly how they cause the knock, but i know i don't show any knock with my poly mounts. the motor sits very still.
Old Nov 18, 2004 | 09:44 AM
2MuchRiceMakesMeSick's Avatar
Back to life.............
I want to run solid motor mounts on my daily driver with a trex. Any problems on my aluminum block? Whats this I hear about KR?
