Trying to relieve crankcase pressure...
I spoke to my builder and he said I need to vent some more crank case pressure. I have a few options to choose from:
1) Moroso evac system and use my current catch can (I have open headers)
2) Ls6 Valley Cover with catch can and get rid of oil cap breather
I wanted to get some opinions, I have heard of people continuing to get blow-by even after the ls6 valley cover swap. Also I have heard mixed reviews about the evac system.
Basically I need to vent the most amount of crank case pressure to relieve small oil leaks and blow-by without spending 500-1000 on a vacuum pump.
Thanks guys!
for people to run these evac and vacuum pumps I can't be the only one suffering from this.
I am just trying to get opinions on the best way to remedy the issue.
I have a roadrace miata that is ls1 powered and I guess I has the breather/pcv system hooked up completely wrong or I have a lot of blowby/crankcase pressure as it pushes oil right past my valve cover gasket on the pass side but not the drivers side (wierd?) when used at high rpm/load.
Looking for the best remedy for this. Possibly just a factory diagram of the correct hose routing.
But mine has 2 90 degree vents on the pass valve cover (1 for fresh air, and I assume 1 for the pcv line, but the drivers valve cover has a rubber grommet at the back big enough that it has a pcv valve in it, unlike the pcv valve in the line like you speak of.
According to vin the motor came from a 02 z28.
Not gonna lie, I'm pretty green to the Ls motor. But I'm willing and wanting to learn.
One more question What happens do the driver side rear valve cover port. Does it just get plugged or is it routed to the passenger side?
Here is what I am going with
