PRC 6.0L Stage 2.5 CNC Ported Heads VS ported 243
Old 08-19-2013, 10:02 AM
Gotsom02's Avatar
Default PRC 6.0L Stage 2.5 CNC Ported Heads VS ported 243
Hi, I was just wanting some input on what head is better for performance/price
The prc 6.0 stage 2.5 cnc ported heads vs ported 243
Old 08-19-2013, 10:23 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Its basically the same either way you go. The 6.0 just has a larger chamber. You just have to figure out what size you are needing and choose accordingly. If its an all motor application you will most likely need the 243
Old 08-19-2013, 11:50 AM
Gotsom02's Avatar
Yes the motor will be N/A. I plan on doing fast 92 intake/tb , torquer v3 or a custom grind, and a3600 stall with a set one of those heads.
Quick Reply: PRC 6.0L Stage 2.5 CNC Ported Heads VS ported 243
