aftermarket starter
Old Aug 29, 2013 | 08:55 PM
bpopham22's Avatar
Default aftermarket starter
Well I'm pretty sure my starter is going out and ill be doing my heads and cam swap soon so it will be perfect timing. I called the dealership and they want 450 bux for the gm starter,but I found a powermaster starter for $180. Is anyone running an aftermarket starter with long tube headers installed? I wanna make sure I won't have clearance issues.
Old Aug 29, 2013 | 09:19 PM
Gray86hatch's Avatar
I have a MSD and it has worked great. crank speed was faster than the stocker.
Tim
Old Aug 29, 2013 | 09:43 PM
Decadence75's Avatar
Rock Auto has them for as cheap as $90
Old Aug 30, 2013 | 07:02 AM
bpopham22's Avatar
Do you have longtubes installed? I did see the msd one so that is an option
Old Aug 30, 2013 | 07:04 AM
ss4chad's Avatar
The factory starter (or the one O'Reilys, Autozone, Pep-Boys, Advanced or eBay sells) will be just fine with your setup. No need to spend the extra cash if you dont have to.
I run 1 7/8 LTs with an MSD starter. No issues at all. I have a stroked motor with dome pistons so I am about 12.5-13 to 1 CR. I needed a high torque starter and the MSD is doing the job!
Chad
Old Aug 30, 2013 | 08:03 AM
bpopham22's Avatar
Well I think I'm gonna go with the msd. My compression will be at 11-1 but I know that's barely higher than an ls6. The stealership wants too much for the gm replacement
Old Aug 30, 2013 | 12:08 PM
ss4chad's Avatar
Great choice! I love mine, turns way faster than the stock one did on a stock motor. its fully adjustable with two (2) different adjustment points.
Plus it's red and matched my powder coated red oil pan and red car! WIN -WIN!!
Chad
Old Aug 30, 2013 | 12:53 PM
redbird555's Avatar
I had the msd one on my car and it was a great piec e just a fair warning though if you have ARH headers or plan t get some the msd wont clear. I had to give mine up when i switched to arhs and just got a stock one from rock auto
Old Aug 30, 2013 | 01:17 PM
HioSSilver's Avatar
You can put a oe lsa starter in it and save 1lb.
Old Aug 30, 2013 | 02:25 PM
sjsingle1's Avatar
Old Aug 30, 2013 | 03:10 PM
bpopham22's Avatar
Well **** I have 1 7/8 arh headers......hmmmm
Old Aug 30, 2013 | 03:44 PM
bpopham22's Avatar
Does the pure energy one from rock auto fit with headers?
Old Aug 30, 2013 | 04:53 PM
It should be a direct OE replacement fit.
Old Aug 30, 2013 | 10:35 PM
01ssreda4's Avatar
I bought a Summit starter blanket to wrap mine in to protect it from header heat and hopefully extend its life.
Old Aug 30, 2013 | 10:59 PM
cookba's Avatar
other than 1 pound lighter how does the LSA starter differ from the stock LS1 starter?
