Cutout Install - A somewhat different approach
Old Nov 24, 2004 | 01:45 AM
Keenov's Avatar
Originally Posted by maximumrebel1
My question is could I or should I buy a cut out (non electric) and cut the cat and put it where the cat's used to be?
You could and I think you should.
I have heard that unless you are going to cam it or what not that you shouldn't remove cats.
I don't know where you got that from, but cats are useless unless you need them for emissions If you remove them, you will gain power no matter if you have the stock cam or not. Most people use cats to kill rasp or for emission purposes.
If you do not need the cats, ditch them. Take the AIR system off too, if you remove the cats.
Old Nov 24, 2004 | 10:07 AM
RA122624's Avatar
I originally posted cat questions in the truck section. I have the 5.3 x cab truck. I am thinking defintly of taking them off just wanna make sure none of the guru's at ls1tech say "wait don't do that what the hell are you doing".
Old Nov 26, 2004 | 12:13 PM
RA122624's Avatar
TTT anyone else wanna chime in?
Old Feb 2, 2005 | 12:58 PM
matts22's Avatar
I have the Streetpro electric cutout. I wish I had gotten a replacement switch, but oh well. I might end up putting the cutout on a different vehicle anyway since I'm probably going with true duals.
Anyway, I had a lot of trouble finding a place to mount the switch. But I wanted to find a place that I wouldn't have to cut/modify the interior. So I ran the wires underneath the passenger seat, up through the center console, and then mounted the switch right next to where the plug for the pcm is. I just took a piece of the padded 3m double sided tape and stuck it up there (if you look, there is a flat space, and it looks pretty good). I just don't like how the switch is lit up all the time. It works for me though. I wired it in with the hot wire for TCS so it comes on with the ignition.
I would post a picture, but I'm at college and don't have a digital camera (yet). If you really want to see it, I can take a picture next time I go home. But there are probably better permanent mounting options.
Old Mar 24, 2005 | 12:54 PM
LS1 Sounds's Avatar
I like the idea of mounting the switch down on the seat! Where did you place the LED?
Old Mar 24, 2005 | 01:07 PM
Coy's Avatar
Coy
does the exhaust blow directly onto the axle in that position? Very clean install.
Old Jan 16, 2006 | 12:24 AM
bowtieordie's Avatar
AWSOME Soloution!
Old Jan 16, 2006 | 07:03 AM
Billiumss's Avatar
WOW, old post but never saw that before, I might have to redo mine to gain a bit of ground clearance...
Old Jan 16, 2006 | 08:03 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yes it is! Your install makes me wish I had kept my QTP's.....
Old Jan 16, 2006 | 10:31 AM
LS69TA's Avatar
Another thread back from the dead I really wish I'd put mine there. Maybe when I get around to redoing it I'll try that. I've got something that rattles, it sounds like the QTP cutout.
Old Jan 16, 2006 | 06:55 PM
jimmyblue's Avatar
Moderator
It looks like it, when the axle is hanging, but on the
wheels the axle is well above the outlet. I've thought
about adding a stubby turndown.
Old Mar 12, 2006 | 06:59 PM
  #32
32of32's Avatar
Question
Alright, I'm ready for my DMH install and I think I'll do it this way!
Any thoughts on RWHP gain in this location vs. a cutout in the I pipe.
Old Mar 12, 2006 | 07:57 PM
  #33
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
probably no gain. just a little farther back.....
Old May 28, 2010 | 04:20 PM
  #34
cyberkill's Avatar
That's the same location I used for my QTP Oval E-Cutout. It comes with a long (10" maybe) oval pipe that you can cut or whatever to make the whole thing fit to wherever want. Speed Inc. did a real good job with mine, and the thing sounds AWESOME! I got it done just a day after i finished Pacesetter LT + TSP Cat Y.
Strange thing is...SOTP or Butt Dyno...I feel like it's faster with it closed than open...but we'll see what happens after a tune and when I take it to a real dyno.
Old May 30, 2010 | 12:47 PM
  #35
LS69TA's Avatar
Whew..4yr old thread back from the dead I ended up putting mine in the same place after my QTP crapped out on me. Plus it wasn't as loud inside the car.
Old Sep 1, 2010 | 09:49 AM
  #36
libertyforall1776's Avatar
I thought the closer to the front, the better for a diverter/cutout?! That's what No Weeds says...
Old Sep 1, 2010 | 09:57 AM
  #37
Zed style? What's that?
Originally Posted by slow
makes sense, just in the 50 or so cutout pic posts i've only seen I pipe, Y pipe, and Zed style ones.
Ryan.
Old Sep 1, 2010 | 11:55 AM
  #38
Black00Z's Avatar
Wow--double dead post revival. This is a zed style cutout
https://ls1tech.com/forums/generatio...ed-cutout.html
Old Feb 6, 2011 | 08:36 AM
  #39
ncsu602's Avatar
Ok, re-reviving an old post. I'm looking to do the same thing and was curious if anyone had any other pics. Any opinions/gains/losses/complaints/etc from this location??
Old Jan 10, 2012 | 01:22 AM
  #40
Ws6kid.'s Avatar
looks very good!!!
