blind leading the blind....
how hard is it to do an intake manifold on a 99 fbody for the first time???
I read how-to and my buddy Jeff has done the job before just not on an fbody...and he's doin it for me so it's blind leadin the blind kinda
heheh Trending Topics
I'm sure you can do it in 6hours reading jmX's instructions.If we really tried, we could have been done in 3hrs or less. (air tools rule)
-Steve
What most ppl do when they get the bolts off the intake is they immediately want to pull forward without routing the brake booster hose away from the sender unit (it wraps around it. Disconnect the brake booster hose and just move the intake a couple of inches forward, reach back their and disconnect the various connections (see link below) - then you can lift and pull the intake forward.
As for the knock sensors, be careful in removing the clips from the actual sensor. You dont pry on them to disconnect - you have to pinch the sides and pull up (dont force it, if you have to force it then its still clipped). Pay attention to torque ratings, the knock sensors only require 11ft lbs - hand tighten then torque.
Here is a good write up - www.ls1howto.com.
Good luck and post back if you run into difficulty.
