Pacesetter LT Install
Old Oct 12, 2013 | 06:51 AM
lastcall190's Avatar
To delete EGR, block off plate for header and expansion plug for intake manifold.
-J
Old Oct 12, 2013 | 10:55 AM
badformulaLS1's Avatar
Originally Posted by BigCityFire
The EGR is set up for the 00-02 years, not the 98-99 emissions so they won't bolt up. I guess I will have to delete it.
What does that involve? I know I need a block off plate on the headers. What else?
I'm new to this, so stick with my noobness.
Thanks!
I don't remember for 00s but 01 and 02 cars did not have the EGR system at all.
Old Oct 12, 2013 | 01:01 PM
BigCityFire's Avatar
The pacesetter headers for 00-02 come with the ports for it. Like I said, I'm new to this so you'd know more than I would. All I know is I need the emissions provisions in Pa if I ever want to pass inspection again.
Old Oct 12, 2013 | 04:22 PM
Here's a thought, maybe you can find someone who deleted the EGR of a 2000 car and install that on yours. Intake manifold is the same, just has a different spot on the headers I suppose. Good luck
-J
Old Oct 13, 2013 | 07:06 PM
Mavn's Avatar
"I MAID THEESE"
Good luck on the install
Old Oct 13, 2013 | 07:41 PM
demonspeed's Avatar
It's not mine! woo hoo!
I would just remove your EGR valve and plug the hole on the top of the intake manifold. I believe can still retain your AIR system even without EGR, so it should still appear as though you have all emissions. Unfortunately, you'll be getting a SES light unless you have the EGR tuned out.
Old Nov 8, 2013 | 12:32 PM
Been driving around with these on for a little while (car is stored away for winter now). It is a bit raspy with the SLP LM2 exhaust, but not as horribly loud as I thought it would be. Very noticeable increase in performance. It accelerates like an entirely new vehicle. Fitment is fantastic. I don't think I lost any ground clearance at all. Check the pics...
Old Nov 8, 2013 | 02:58 PM
demonspeed's Avatar
Awesome
Old Nov 8, 2013 | 06:07 PM
GscrillZ28's Avatar
That looks awesome bro! Did you use pacesetters ORY?
Also how is the smell is it as bad as people say?
One more question did you use those coupling bands or did you weld on the ORY?
Old Nov 9, 2013 | 02:20 PM
Yes, I used the Pacesetter ORY. It smells pretty bad right now. lol I am hoping once I put the new intake and throttle body on and get it tuned that smell will go away. Can anyone confirm or deny that the smell will go away with a tune?
Old Nov 9, 2013 | 07:53 PM
demonspeed's Avatar
The smell will go away after putting some miles on it.
