LS6 valley plate question.
Old Nov 21, 2013 | 01:59 PM
ajzcamaro's Avatar
Default LS6 valley plate question.
OK, my car is listed below in the signature. It has the LS6 block from the factory. My question is this, did the LS6 block camaros automatically receive the LS6 valley plate? Also, how do I know if I have an LS6 valley plate on my car?
Old Nov 21, 2013 | 05:23 PM
conan's Avatar
The ls6 valley plate will have a PCV nipple in the front of it. It sticks out to the passenger side under the throttle body.
https://www.google.com/search?q=ls6+...8%3B1024%3B768
Does your car have this ^^^
Old Nov 21, 2013 | 09:48 PM
demonspeed's Avatar
It's not mine! woo hoo!
LS6 valley plate -- the one that matters -- wasn't introduced until 2004. Further, it's the PCV system that is the difference, not the LS6 itself. Thus, if one has a LS6 block from the factory, they have only that -- the block (and the intake manifold that every LS1 got in 2001-'04).
Old Nov 23, 2013 | 12:23 AM
01ssreda4's Avatar
No you don't have it unless someone installed it after the fact.
Old Nov 23, 2013 | 09:19 AM
ajzcamaro's Avatar
Which picture are you referring to in those search results?
Old Nov 23, 2013 | 01:52 PM
conan's Avatar
http://www.google.com/imgres?sa=X&bi...9,r:3,s:0,i:90
Old Nov 23, 2013 | 08:27 PM
ajzcamaro's Avatar
I'll have to check, I'm not sure. Thanks.
Old Nov 24, 2013 | 02:32 PM
JakeFusion's Avatar
Super Hulk Smash
You just don't have to grind the block to get it to fit. Yay for you.
Old Nov 24, 2013 | 03:57 PM
Majestic9C1's Avatar
Grinding the block is no big deal. Took me less than 10 minutes and only used 1 cutoff wheel on my dremel
Old Nov 24, 2013 | 09:28 PM
ajzcamaro's Avatar
I checked today and it's the stock/standard LS1 valley plate. Guess I'll upgrade that when I get a FAST intake and do some head work.
Old Nov 24, 2013 | 09:30 PM
1BAD98LS1's Avatar
That's the easy part, hard part is keeping the debris from getting down inside the engine lol
Old Nov 24, 2013 | 10:29 PM
True, I just layed some towels all around it and used a vacuum and a wet rag to wipe up the aluminum dust
