Exhaust help.
Old Dec 6, 2013 | 09:09 PM
02Z281SC's Avatar
Default Exhaust help.
I currently have an 02 Z28. Im running pacesetter longtubes with an ORY and a slp catback that the muffler has been swapped out with a magnaflow bullet. Any suggestions on what catbacks would be a little quieter? Would a oval magnaflow catback be quieter than the bullet style muffler I have now?
Old Dec 6, 2013 | 09:12 PM
HCI2000SS's Avatar
I have that exact same setup actually, but with a Flowmaster merge pipe welded in place of the crappy Pacesetter merge on the headers. It really helped as far as eliminating the rasp, and making for a smoother deeper sound. It was only like $50 dollars to boot. Might want to check that out
Old Dec 6, 2013 | 09:15 PM
Blownbayou's Avatar
try to find the SLP dual/dual muffler...... Best sound IMO
Old Dec 6, 2013 | 09:31 PM
02Z281SC's Avatar
Would this be the correct flowmaster merge?
http://www.summitracing.com/parts/FLO-Y300400/?rtype=10
ragtopz28's Avatar
^^agree, but good luck on finding someone wanting to part with it. The Hooker Aerochamber is pretty quiet.
Old Dec 6, 2013 | 09:33 PM
ragtopz28's Avatar
I think you need the 2 3/4 inlet for the pacesetter ORY
Old Dec 6, 2013 | 09:34 PM
HCI2000SS's Avatar
Yes sir
Old Dec 6, 2013 | 09:36 PM
02Z281SC's Avatar
A bit confused. What size would I need? If that wasn't the correct one could you send me a link to the correct size I would need?
Old Dec 6, 2013 | 09:39 PM
HCI2000SS's Avatar
That is the correct one
02Z281SC's Avatar
You don't happen to have an exhaust clip of your setup do ya? JW if i can tell the difference with or without the merge.
Old Dec 6, 2013 | 09:42 PM
HCI2000SS's Avatar
Sorry I do not, but I can assure you there is a nice difference. Just ask around
Old Dec 6, 2013 | 09:47 PM
ragtopz28's Avatar
If you go with the 4" outlet you will have to neck it back down (unless you plan on going 4" over axle. Either way, I did the FM merge and it drastically reduced the rasp!
Old Dec 6, 2013 | 09:54 PM
02Z281SC's Avatar
Alright thanks a ton guys ill give it a shot
Old Dec 6, 2013 | 10:16 PM
HCI2000SS's Avatar
No problem, keep us posted
