Less bulky coil packs...
How do the older triangular shape (D581) coil packs compare to the round LS2 (D514A) or newer round truck (D585) coil packs. How about something flatter like the LS3, LS7 (D513A), etc.
I'm currently running the D581's and they are fine, but I want to relocate/hide the coil packs this winter. The D581's are bulky and they way they mount isn't conducive to making a smaller footprint. In fact, I've only seen one company that makes a bracket for them and it's not as small as I'd like. The problem is that the bottom mounting hole lines up with the spark plug boot, so you can't mount them face to face.
I tried the LS1 (D580) coil packs hidden under a set of Edelbrock covers, and I felt like the car didn't pull as hard in the higher RPM's. Just a butt dyno, but I swear I could feel the difference.
Here we have one guy saying he felt a loss of power going to LS1 coils.
The only coil that's really "better" in performance is the round truck coils with the heat sink. They've been tested and have more milliamps output. These are also the only coils that will need a tune update.
Without claiming they "make" more power, I will say they improve an engine's response.
I do believe the first original LS1/6 coils have less output.
You can hide the coils anywhere you want under the hood. You'll just need to extend the coil harnesses and get custom (make em' yourself) plug wires.
LS1/6 coils have different plugs then all other versions.
Put the coils on the frame next to the radiator and have Current Perf make a harness, then you make your own wires and secure them with billet clamps. It would be nearly invisible and clean up the engine bay. But then you have to buy new valve covers, where does it end!!!!!
Chad
I'll probably look for a set of LS3 coils and try to find a stealthy location for them. I was just looking for ideas. I tried mocking the LQ9 coils up in a couple of different locations, but due to their mounting holes, they still end up taking up a fair amount of space.
I'm not worried about lengthening the pigtail, or fabricating longer spark plug wires. I'm just waiting to see a location I haven't thought of yet.
I had an 04 Escalade with an LQ9, and when going to buy plugs for it (MSD) there's actually 2 different ones available. One for the round Melcos and one for the square Delphis. Different length wires for each.
Doing the swap:
The coils are 10457730 (GM part number) (AC Delco part number D585), eight coils needed.
The coil mounting brackets are 10457736 (GM part number), two brackets needed.
The coil harnesses are 12601824 (GM part number) two harnesses needed.
Good luck! Paul Bell
AC Delco D-585 assembly
AC Delco D-585 Coil
AC Delco D-585 Connectors
AC Delco D-585 Harness 1
AC Delco D-585 Harness 2
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 1
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 2
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 3
12-10-2013 AC Delco D-585 and coil harnesses 12601824 assembled 4
Those parts plus shipping was $593.86.
12-11-2013 D-585 Mounted 1
12-11-2013 D-585 Mounted 2
12-11-2013 Firecore50 custom 1
12-11-2013 Firecore50 custom 2
12-11-2013 Firecore50 custom 3
12-11-2013 Firecore50 custom 4
Christian
