Home ported MAF vs. aftermarket??
Anyways, my point being that it's not really worth anything considering the stock maf is good up to around 500 hp.
By the way, I ported my own MAF and ran into no problems, but I didn't notice a gain either.
-Sly
I don't know if the aftermarket mass air bodies are calibrated so the fluid line pressure does not reduce. Maybe somebody knows.
If you have enough cam, high flowing/high compression heads, killer intake and exhaust then a little larger mass air will improve hp assuming it calibrated correctly. The factory mass air is equivalent to a 66.2 mm bore. May not be big enough for a hot engine.
Josh
-Sly
