Kooks True Duals - Clamps/Welding
I got my set a little while ago and all of my pipes slide in to bottom out on the expanded portion. If yours arent going in the whole way I would say to get a pipe expander and just open up the female end of the pipes a hair at a time until they fit flush. After that use an impact to crank down the clamps. If you are still getting leaks a trick I've come up with is to use a wrap or two of exhaust tape under the clamp to make a gasket like covering that wont mess up the pipes.
i was in the process of installing my kooks headers and true duals. im not that impressed so far with the fit especially for the money. i had to put a dent in the passenger side primary to clear the k-member because it was touching it. wasnt about to have them make me a new set and wait a month for it to get powdercoated all over again lol.
now that the headers are bolted up, i am installing the exhaust and it seems like at some of the joints the pipes are almost too short where they wont go all the way into the expanded portions. the main area is by the x-pipe where it joins with the pipes coming off the headers. I have to basically use force to pull the two downpipes together towards the middle of the car just so that the x-pipe will be sliding over the downpipes enough to not have any potential air leaks. any way around this at all?
Also, I had perfect header fitment.
thanks. after a LOT of messing around i think i finally have it set up so that it wont leak. havent started it up yet still need to fully tighten everything but it took a lot of small adjustments and movements of each individual pipe to get it right.
overall its a great system just takes some time to get it right especially under the car on ramps lol. only thing that kinda sucks now is the heat tape that it comes with i went to stick it on and it wasnt even sticky lol. not sure if it was because it was cold out or not....
^^^ I always heard it's best to clean the gas tank before you place the tape. I'm go get the exhuast soon but before I place the tape I plan on cleaning the tank off with purple power and acetone.
#36
That was my strategy
I'm interested in this as well. I'm considering taking off my stock heat shield this weekend since I get slight vibrations from my exhaust and the shield occasionally.
#39
I ordered Thermo-Tec Adhesive backed heat barrier. It was 12x24 and I used most of it but just covered up alot of the gas tank to be sure. You dont need a whole lot but a hell of a lot more than what is provided with the TD's. It stuck really well after cleaning the tank up. You can get it at a local auto store too, I know Advanced Auto carriers it but they were out of stock when I went so I grabbed it on Amazon. Its around $20.
