Kooks True Duals - Clamps/Welding
So my questions are...
- What is the correct placement of the clamps on the joining of two pipes?
- Would I be better off just having the majority of the joints welded?
Here is what all the joints on the kooks system look like:
Thanks for the help.
Devon
put it on the joints...put your clamp on over it....tighten the crap out of the clamps...
you wont have to worry about leaks any more after that.
If I were to buy a welder myself to do the tack welding, what would be a good setup? It's nearly impossible to find a shop around here that can get my car on their lift because it's lowered.
I'll also look into that exhaust sealer.
Thanks again for the help.
Devon T.
Devon T.
realistically, any Lincoln or Miller welder will do exhaust work
Just stay away from off brand welders..
Stainless Steel Exhaust Weld Repair - YouTube
that guy does good work, I've watched a bunch of his videos....
he does do a bit of overkill though...
for most things you dont need a big purge like he is doing, especially for just a tack weld
and you will need stainless wire..
