really confused????
my body guy, friend of the family since parents were in highschool.
I asked him about the install, labor and all that other fun stuff. He claimed that to install this on the ls1 you have to pretty much drop the "frame" with the engine and trans out from "under" the car. He claimed that its a hassle and everything.
long story short he said to do all that it be 5,000$ ???????????????
He builds his own cars one runs 10 secs. the other runs 9 sec. so he is knowledgeable and knows what to do.
Is it really this much and hard to install H C I
Check the internal section here and read of the many H/C builds.. %90 of them are done to engines still in the car..
[img=http://s308.photobucket.com/user/jsteele90/media/Mobile%20Uploads/motor.jpg.html]
[/img] The Best V8 Stories One Small Block at Time
6 bolts for the k-member, 6 for the struts, 4 for the trans cross member, some connectors and other stuff. Took about 2 hours, this was my first time.
If he wants that much it's because he doesn't want to do it. If he isn't into doing the job you don't want him working on the car.
If you can't do it yourself check with members in you local area for suggestions.
Good luck.
Just get a good torque wrench, borrow a socket set and follow the ls1howto.com walk through, minus the way they tell you to install the harmonic balancer and you'll be good to go..
Good luck.
