Waterpump/T-stat?
Old May 13, 2004 | 06:45 PM
02WS6#519's Avatar
Question Waterpump/T-stat?
I just had the waterpump replaced under warranty. Even with my mods! The problem is that the waterpump is an '04 model. And the thermostat is different. The t-stat is seperate from the housing. I found out today after I tried to install my old 160* stat in the waterpump and it wouldn't fit. The waterpump opening is too small. I checked the stat with an old school model 160* stat and the openings were the same. It has a rubber gasket that fits on the stat. Can I use an old school 160* stat? Or can I modify the stat that is on there already? If so how? Drill two holes on it? My car is tuned for a 160* stat.
Thanks in Advance
Ever
Old May 13, 2004 | 10:26 PM
02WS6#519's Avatar
Bump!
Old May 14, 2004 | 03:57 PM
02WS6#519's Avatar
Anyone know if I can use a SBC 160* thermostat? It fits.
Thanks
Ever
Old May 14, 2004 | 04:49 PM
02WS6#519's Avatar
Old May 14, 2004 | 04:51 PM
Nasty N8's Avatar
Never heard of this got a pic?
Nate
Old May 14, 2004 | 05:06 PM
02WS6#519's Avatar
I'll try and post some pics later.
Peace
Ever
Old May 15, 2004 | 11:27 PM
highgear's Avatar
Cool
You had it replaced under warranty???
Take it back and make the dealer put the correct pump on for an 2002 model.
Then everything should work as before.
Old May 16, 2004 | 12:45 AM
02WS6#519's Avatar
Good point. But too much of a hassle and down time on the car since it's my daily driver. I drilled two holes on the stat and the temps are hovering around 165*-175*. Is that ok? Or should I just install a SBC 160* stat? It fits perfectly.
Peace
Ever
Old May 16, 2004 | 09:20 AM
DANSLS1GTO's Avatar
I don't know the answer to your question - but apparently the GTO's have 2 different water pumps. At some point near the first 500 cars, they switched to the new housing.
http://www.ls1gto.com/forums/showthr...ght=thermostat
Dan
Old May 16, 2004 | 11:30 AM
minivette's Avatar
04 Corvettes have the new waterpump.
Old May 16, 2004 | 08:36 PM
02WS6#519's Avatar
I Guess I have the '04 vette waterpump.
Old May 16, 2004 | 09:22 PM
Johnny5's Avatar
I just had this exact same issue a while back.
Here's a few pics.. it can be done but probably not so easy while on the car nor would I recommend it. With a bit of the dremel it can be done.. no leaks here after a few thousand miles
Old May 16, 2004 | 11:51 PM
02WS6#519's Avatar
That's it exactly. Thanks for posting the pics. People were beginning to think I was crazy!
Peace
Ever
Old May 17, 2004 | 12:37 AM
Johnny5's Avatar
yeah.... I know what you mean.. when I posted the same thing I didn't even get hardly a response
I even called a few sponsors to see if I was doing something wrong....
Old May 17, 2004 | 01:10 PM
02WS6#519's Avatar
Hey Johnny5, do you have any pics of the two different thermostats?
Thanks
Ever
Old May 17, 2004 | 11:30 PM
Johnny5's Avatar
nope.. never took a shot of that... The only thing that seemed very different is the width and angle of the two arms (sorry for lack of a more technical word) that wing out and around to the bottom of the stat. That's where the notches had to get smoothed out.
Old May 20, 2004 | 01:24 PM
02WS6#519's Avatar
Here is a pic of an LT1 thermostat----->
Which looks exactly like the stat that came with the new waterpump. Exactly. So does that mean I can use an LT1 160* stat? They are both reverse flow, right?
Thanks
Ever
Old May 20, 2004 | 01:26 PM
02WS6#519's Avatar
The LT1 Hypertech stat is way cheaper than the LS1. Like $20. Someone let me know asap so I can go purchase one.
Thanks
Ever
Old May 23, 2004 | 11:19 PM
02WS6#519's Avatar
I bought the LT1 t-stat and it wasn't the same as the '04. It was shorter. I guess I'll wait until they come out with the newer version. Or maybe modify it with the shims. I don't want to modify the waterpump like Johnny5.
Peace
Ever
Old Jun 11, 2004 | 07:55 PM
00SSLS1's Avatar
i thought i was going crazy too, i have the same problem
