What did u do to get rid of "rasp" sound
#41
I am running into some rasp with my new exhaust setup on my swap and want to get rid of it.
6.0L LQ4
CTS-V (1st Gen) OEM manifolds
dual 3" stainless piping to an X-pipe under the rear seat
Right (passenger) branch after the X-pipe is straight piped out the back with a currently closed cutout dump
Left (driver) branch after the X-pipe goes to the OEM BMW muffler which has a factory Helmholtz resonator. Closed cutout between the X-pipe and the BMW muffler.
Raspy on cold start around 1.5K, and 2.5K.
Would one of these in each of my straight lengths before the x-pipe reduce the rasp? I believe I have the room for it.
http://www.summitracing.com/parts/wlk-24248/overview/
6.0L LQ4
#42
Most of the time the "rasp" that you get from an ory style exhaust is from the quality of the merge itself. Most ory just jam one pipe into the other at a bad angle. That results in a y that doesn't flow all that well because the exhaust pulses from each pipe are bouncing off one another and creating turbulance. This is where the rasp comes from. I almost guarantee if you put a good quality merge in like the Flowmaster merge it will eliminate your problem.
#44
The Scammer Hammer
This is what I did before I went to TD's.
Pay particular attention to what I did to the TSP ORY
https://ls1tech.com/forums/generatio...tall-pics.html
#46
#48
pretty much what I did with mine except I used a 3.5"x9" dynomax bullet instead with an electric cutout right after the muffler. Sounds awesome and has absolutely no rasp at all. Its as rasp free as my old TSP true duals with sweet thunders with turn downs. Its just as loud but can be quiet as stock with the flip of a switch.
#51
I have a custom 2.5 y pipe from a muffler shop ingo a slp 2 an that was realy bad. But i ordered one high flow cat an put it right in front of the slp muffler an that took care of it.. then took off my tail pip an pit dump right before the axel. Sound bad ***.
