Be-Cool Package
I have that. I added a huge B&M trans cooler. With a 160 t-stat and programmed fans, it runs fine...
It's a huge radiator tho at 2.5" thick. But it fits without modification.
The thicker radiator puts the fans pretty close to the engine & stuff on front. I'd think the BeCool fans are gonna be even closer.
Again, no need for the fans, the stockers are plenty so long as they're properly running.
As I recall, I got my BeCool radiator from the good folks at WS6store.
I had half of it blocked with the huge chrs1313 non-AC ram air kit, and living in south Louisiana... It gets HOT.
I never had an overheating issue at all. I coupled it with a 160 stat as recommended by Geoff, and couldn't be happier.
I personally see no reason to go to a 400 dollar radiator when the LT1 can be had for less than 100 bucks and does it's job WELL.
BeCool is definitely a high quality piece you can get with or without the tranny cooler.
I got mine from Advance Auto with a lifetime warranty. Why order it when you can get it online and select "in store pickup" and use a coupon code... All for less than 100 bucks.
I once had an, uh, "issue" when the hose barb on the plastic hose nipple of an original radiator sheared off when the coolant system was pressurized. Needless to say, it made for a very miserable day.
I HATE OEM radiators with plastic tanks & hose nipples and internal oil/transmission coolers that are prone to leaking.
I'll agree they're nice though.
it just doesnt seem necessary unless youre making insane power or running a ton of boost where extra cooling will help.
a well maintained stock cooling system is adequate for most setups from my experience.
, let me ping rpmspeed real quick.
