eBay 92mm throttle body
Old Jul 14, 2014 | 01:46 AM
DylOrr's Avatar
Default eBay 92mm throttle body
I got a good deal on a used fast 90 intake and I decided to try out a 92mm throttle body from eBay since they're a quarter of the price of a NW tb. I put it on and noticed it didn't open all the way but I figured that was kind of normal but I put a data logger on it and the throttle only opens 63%. There is 2 spots on the tb for the cable to go into. Should I try the other one? The cable is adjusted tight, if I adjust it any tighter it idles higher. Fit and finish on the tb is very nice considering the price. Didn't know if anybody ran into this or had any other ideas.
Sorry if there's a video double post or if neither of them work. It's basically just me flooring it while the cars off and the tps showing 63%
Old Jul 14, 2014 | 06:25 AM
poltergeist 02's Avatar
I would look down the throttle body when trying to open it to see what it's getting caught up on. Does it open 100% by hand?
Old Jul 14, 2014 | 06:29 AM
LsoneGT's Avatar
I run the same throttle body with know issues and also run my throttle cable on the same hole yours is. I verified my with hptuners also. If you cant get it figured out have them send you another one
Old Jul 14, 2014 | 08:46 AM
JRENIGAR's Avatar
Subed, as I just bought a fast 90 and need a tb. O.P. keep us posted on what you find.
Old Jul 14, 2014 | 06:04 PM
Have you tried a tps relearn?
Old Jul 15, 2014 | 03:43 AM
DylOrr's Avatar
Opens all the way by hand and accelerator goes all the way to the floor. It's basically like there's not enough cable to pull it all the way around. The blade Doesnt Open straight either.
Old Jul 15, 2014 | 03:44 AM
DylOrr's Avatar
Is there a way to adjust ratio on how fast the throttle pulls the cable?
Old Jul 16, 2014 | 07:46 PM
Werewolf SS's Avatar
First do a TPS relearn, unplug the tps sensor turn the car to the on postion (don't actually crank). Wait about 10 to 20 seconds then turn key to off, plug TPS connector back in and then see if it registers as opening 100% when you put the throttle down.
Old Jul 16, 2014 | 11:09 PM
JRENIGAR's Avatar
What do you mean by"the blade wont open straight"? Have someone verify that when you put the pedal to the floor that the actual tb blade either does or does not open all the way. Lets get the tps reading out of the equation for now and concentrate onv the actual tb blade movement.
Old Jul 17, 2014 | 04:33 PM
DylOrr's Avatar
I may be able to relearn the tps but the blade still opens 60% of the way regardless. I would rather it open up all the way. I watched it, It doesn't open all the way.
Old Jul 18, 2014 | 11:00 AM
JRENIGAR's Avatar
Well then a TPS realearn will do you no good. Id try to figure out a way to make the cable open it all the way up and close all the way when off the throttle. If not then its useless, send it back.
Old Jul 20, 2014 | 02:52 AM
DylOrr's Avatar
Well I was just out messing with it and if I hold it to the floor and have a buddy turn it the rest of the way wide open it stays wide open. I know the spring on the tb is really tough, harder than any other tb I've seen.
Old Jul 20, 2014 | 07:01 PM
DylOrr's Avatar
Another update. I pulled the cover off the throttle box where all the cables go in and after I open it I can turn the cam around and open the throttle up the rest of the way. Is it possible my cable is stretched. I also noticed that I can lift my pedal and the cable doesn't pull the throttle all the way back up. Anybody have any idea on this one? Throttle cable stretched? .
