Custom made 4" Velocity stack Intake system
Old Jul 21, 2014 | 09:42 AM
04BlackGmc's Avatar
Originally Posted by idle
You need to produce 20 of them and sell for profit. I'd buy one; definitely an interesting setup and something you don't see often.
You could have a quick-disconnect on the rolled inlet to allow for a cone-filter and then drill holes or slots in the front license plate cover.
Yea has a cone filter for the street on it.
Old Jul 21, 2014 | 09:43 AM
04BlackGmc's Avatar
Originally Posted by Rise of the Phoenix
What part, and where did you get it, did you use for the IAT relocation?
What part? Used this for IAT
http://www.aemelectronics.com/?q=pro...ure-ait-sensor
Old Jul 21, 2014 | 03:21 PM
04BlackGmc's Avatar
Well the results are in..
Changes were a new custom grind cam From the man Martin@Tick
.040 Head Gaskets
4" intake system seen above.
Don't mind the Tq spikes with the converter unlocked
47 Hp gain locked and unlocked
Unlocked After
Before and After unlocked
Before and after locked
Old Jul 21, 2014 | 03:46 PM
Rise of the Phoenix's Avatar
How much bigger is the new cam? Curious how much alone was from the 4" intake setup.
Old Jul 21, 2014 | 03:48 PM
04BlackGmc's Avatar
It's a step up that's for sure. Car drives great i think with my tune of course lol.
Old Jul 21, 2014 | 03:53 PM
I'm going to try to do this before I come up for the tune in August. I assume I'll need 3" tubing though since I'm running a LS6 intake and stock TB.
Old Jul 21, 2014 | 03:57 PM
04BlackGmc's Avatar
Previous Duration was
231/235
Now it's
239/246
Old Jul 21, 2014 | 04:12 PM
Zmg00camaross's Avatar
I had my ram air and know it picked up. Always wanted on like this you guys beat me to it. I know this ram air style flat works. Guess I will be a copy cat but on a Camaro. Time to get to my buddy's tig! . Shane what's samsel NA numbers? Edit. Idk how I would hide a air filter behind my billet grille. Going to get creative I suppose.
Old Jul 21, 2014 | 04:18 PM
Sales@Tick's Avatar
Damn impressive Shane! You guys hit that one out of the park!
10.8@126 with the old power curve, wonder what it runs now?
Old Jul 21, 2014 | 04:19 PM
04BlackGmc's Avatar
Martin has some pics on his car when it was NA.
10.8@126 NA before.
Old Jul 21, 2014 | 04:26 PM
Sales@Tick's Avatar
If you look in my avatar you can barely make out the velocity stack poking out the catfish mouth on the pass. side.
Old Jul 21, 2014 | 04:32 PM
  #32
Martin, am I correct in thinking I'll need 3" tubing with a stock TB?
Old Jul 21, 2014 | 05:00 PM
  #33
Sales@Tick's Avatar
You can do a 4" to 3" reducer which is what I would do personally.
Old Jul 21, 2014 | 05:09 PM
  #34
04BlackGmc's Avatar
+1
Old Jul 21, 2014 | 10:12 PM
  #35
I remember martins car with it. Did you have any data Martin? Before or after that style intake?
Old Jul 21, 2014 | 10:18 PM
  #36
RobsZ28's Avatar
How do you guys think this 4" Velocity stack Intake system would work on a 11.1 347ci LS1 with Super Victor intake, Accufab 4150 t/b, and Extreme Velocity 4150 Carb Hat.
Old Jul 21, 2014 | 10:25 PM
  #37
It would work!! Myself was never a big fan of the lid. But myself at this time have a sux2bu style ram air and defiantly worked and the car picked up. This style with it going directly to the TB or carb works well. Reason prostock cars have giant hood scoops with air pans. If your a max effort kinda guy then doing something like that is beneficial.
Old Jul 21, 2014 | 10:39 PM
  #38
RobsZ28's Avatar
It's max effort nitrous 347ci
I only have 2 options at this point, cut the extended Sunoco hood by the windshield and add an air pan or a setup like this. I've read on here and been told by other that with a 4150t/b an air bell and air pan are the only way to go. I'd rather not cut a 4"-5" notch in the hood if I don't have to, I'm just worried about the hat hurting performance.
Old Jul 21, 2014 | 10:56 PM
  #39
Sales@Tick's Avatar
I think with the 4150 hat you'll be fine. Only one way to find out for sure though and you won't know until you try it.
On my car it was worth almost a tenth and almost a full mph in the 1/8th. In the 1/4 it would of shown an even larger improvement.
Old Jul 22, 2014 | 06:28 AM
  #40
idle's Avatar
So are there any plans to produce a few dozen of these and sell?
