Which wires to ground for ABS/TCS delete dash light?
i've read several threads that say there's a wire or two you can ground out after you've deleted ABS/TCS and it will kill the lights in your dash.....but they never actually say which ones, only alot of bickering back and forth on whehter it's a good idea to remove ABS/TCS in the first place.....i tried searching, but is there an actual write up on this?......anyone else done it and know which wires need to be messed with?
