Cammed LS1 not as fast as it use to be
At one time the car pulled amazing. I couldn't hook at all rolling at the top of first gear or even from a roll in second gear. And when it did get traction it pulled hard.
Now the car is still quick, but does not pull like it use to. I can no longer break traction in first gear, and especially not second gear. It no longer pulls really hard. However, every now and then, 1 out of maybe 30 pulls, it will pull like it use to.
I have a check engine light on for clutch switch, and that is all.
All my sensors seem to be plugged in, and it seems I have good connections everywhere. What could this be?
Could a bad knock sensor do this without throwing a the check engine light on?
The motor had 70K miles on it, but I tore it down and installed new rings, bearings, gaskets, pushrods and springs along with the cam. This was three thousand miles ago.
maybe something wasnt put back together correctly or overlooked.
Get or borrow something that will let you scan and also a wideband.
Ideally you want to see timing is 24-28* and air/fuel is 12.5-12.9 at WOT. You will also be able to see if it's pulling timing due to knock sensors or something like that.
Tune is a mail order. I took the computer to Vengeance Racing, and their tuner tuned it. It is their cam, so I feel as if he provided a mail order tune better than anyone else could.
Could that be it? I know I can squeeze alot more power out with a real tune. But the problem seems to be intermediate.
Traction is relative to a lot of things other than power.
