TSP 1 7/8 header and Y pipe install problems!
Spent a few hours last night.
Dropped the header again and clearanced the k-member, probably knocked out nearly 1/2" with the grinder. Bolted everything all back up.
Next swapped out my cross member and put the stock piece back on.
Mounted the TA back to the tail shaft for now until I can find a more permanent solution. I forgot how much of a PIA that was, glad I had extra hands. Had to lower the trans and remount the clamshell, pull the torque arm right off the rear and then work back to it.
I will go back to it tonight. Setup the Y pipe, and then play around adjusting my pinion angle. Amongst a few other things.
Maybe you should have spent 4x more on a different brand, so you wouldn't have to "hack" your 15yr old car.
As far as the driveshaft loop, I have seen the Lakewood and Spohn loops that look to be made of flat stock fit without clearance issues.
Lonnie
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
Lonnie
Thanks for the reply Lonnie.
I was curious about 2 things.
1: The Y pipe design, I was curious as to why it was designed in such a way you need to cut a couple inches off the stock length intermediate pipe? This issue seems to be unique to TSP Y-pipe.
2: Regarding torque arms and relocation. Are you aware of any full length combinations that allows clearance with this exhaust and a cross-member with mount relocation? One person chimed in earlier but was curious if you had additional experience.
Thanks again for the reply, these issues are just things I will have to work around and I suppose are different for different setups/cars. But for what it's worth I'm just sharing my experience.
I will say for the $ spent the headers are pretty nice, and the ground clearance with the Y is great as well as a respectable merge. Compared to my old stuff I expect a few more ponies.
Thanks,
Dan
As far as cutting the Y-pipe/ I-Pipe, it's primarily for the stock systems that you have to cut the I-pipe as you will have the neck down to fit the stock 2-1/2" I-pipe. If you have an aftermarket 3" system you just simply cut the neck down off of the Y-pipe to fit a 3" set up. There's not enough room in the Y-pipe with that nice merge to make the neck down an interchangeable piece. It does work out nice too in the fact that if you wish to change to a 3" set up you still have a Y-pipe that will work with that as well. All you have to do is cut the neck down off.
Lonnie
Even after putting my TA back on the transmission I still don't have enough clearance. I started looking at this differently.
The only answer I can see is TSP's exhaust is not compatible at all with Spohn full length torque arms.
The design of the arm has the straight edge of the ladder at the top, where as other arm's (aka BMR) have the straight edge at the bottom. The bottom being straight would grant more clearance.
Take a look at the pics, Lonnie, let me know what you think do I need a new TA?
Maybe I should have spent 4x more on an American made product, not some cheap Chinese header that forces me to grind off pieces of my car. This is one of those cases where you get what you pay for.
Not every car is perfect and built to the same specs as the previous one that rolled off the line. Some have to grind, some don't. Motor mounts, stock, poly, solid, and pedestal all play a value as well.
What don't you understand about that?
You don't want Texas Speed headers, fine. We get that. It's your money. Spend it where you want. Knock off the "cheap Chinese" **** though.
AFWIW: I think what people need to understand is EVERY F body is different, really, these are NOT precision made automobiles, these are massed produced in great quantities and the spec tolerances are all different. I work in a vehicle mass produced manufacturing facility (MIL vehics) and I see the tricks that have to be used to get things in "specs" sometimes. YMMV!
PS: what are the other cars in this killer looking garage, not to change the subject...and what paint did u use to paint your welds?
Long story short, I got the new BMR torque arm in along with my trans cross member with relocation. The Y-pipe then cleared fine. However due to me having to cut the necked part on the intermediate pipe I was not able to clamp down enough to get an even half decent seal. Even using a U bolt its still crappy and hangs a little.
So there are things you should be aware of if going the TSP route.
The headers are nice for the money and the Y pipe is built decent but the fitment sucks. It does however hug the floor well an has a nicer merge than other low cost options. They could have easily at least made it fit the intermediate pipe better without cutting. This would have not only fixed that problem but also allowed me to use my BMR driveshaft loop. The bends would only have been a little more aggressive.
So be aware that the Y pipe will not fit certain torque arms (spohn specifically). Grinding the k-member is very likely. It will not clear BMR or similar driveshaft loops that require the pipe to be fed over the top. You must also cut your I-pipe and ultimately weld it or get a flange welded.
So as the old saying goes, "You get what you pay for", for me this is holding true.
New Torque arm $350
New DS loop $150
Paying a shop to do some welding $100-200 approx.
For me I spent a ton of time working on this for something as simple as headers/exhaust.
This will put me up to the price of ARH, that would have taken only a short day to install. I spent a lot of time and I'm committed to this setup for now, but figured I'd lay out some facts for people to see what you might be getting into. I just need to get some welding done and it will be wrapped up.
New Torque arm $350
New DS loop $150
All in all, when running any aftermarket suspension parts and ordering exhaust products whether through us or anywhere else, it's always a good idea to call first to make sure there won't be any interference issues with your set up. This thread is a good example of that.
Lonnie
So just to be clear, my car already had long tube headers and a Y-pipe from another manufacturer. My torque arm and driveshaft loop were designed with headers in mind and cleared everything fine previously.
When I weld my exhaust up I would like to have the ability to separate the Y pipe from the intermediate pipe so its easier to work on the car. So I will have a reducer/flange added that will obviously increase cost marginally and I assume I will be charged at least an hour labor for everything so my pricing is a good guess.
As I stated in a previous post I'm not of the mindset to slam a vendor. I know when you mix and match parts things can happen. However I am just sharing my experience for face value. There are common challenges with this setup that from a consumer perspective you should be made aware of and from a vendor/builder perspective maybe they can regroup and attempt to make a better product.
