TSP 1 7/8 header and Y pipe install problems!
Old Sep 21, 2014 | 07:03 PM
DannoWS6's Avatar
Default TSP 1 7/8 header and Y pipe install problems!
Today I attempted to install my headers and I ran into a few problems on my car. Headers themselves basically went in ok. Other than removing plugs, coil packs, etc. I did have to remove the alternator, steering linkage, oil filter.
First issue: The drivers side header, one of the primaries is resting right up against my K-member (stock). Just opposite of the oil filter. I want to know the best way to clearance it, should I grind the k-member in this spot or do I need to heat and clearance the primary? I probably need a little more than 1/4". Oh and I already have poly mm.
Second: I have a BMR driveshaft loop, the Y pipe merge will not allow me to run this safety loop as one side will not clear, I do not see any way around this? Anybody know what loops work with a TSP Y-Pipe? BTW in my picture this loop was modified to clearance my TQ arm due to relocation bracket.
Third: I have a Yank Torque arm relocation crossmember. The torque arm hits the Y pipe and I have no clearance to bolt the torque arm and y-pipe without making contact and flexing the ypipe. I am thinking this will not work at all.
What are my options with the torque arm? I am thinking about trying to mount it back to the stock location (for now), but do any full length relocation kits work with the TSP Y-pipe? What about short arm versions?
Oh and for what its worth, I had to cut almost 2" off my intermediate pipe (GMMG catback) in order to get this even close to fitting. I was not too happy about that.
(The last pic is my old stuff)
Attached Thumbnails TSP 1 7/8 header and Y pipe install problems!-imag0157.jpg   TSP 1 7/8 header and Y pipe install problems!-imag0161.jpg   TSP 1 7/8 header and Y pipe install problems!-imag0164.jpg   TSP 1 7/8 header and Y pipe install problems!-imag0165.jpg
Old Sep 21, 2014 | 09:07 PM
mjs1012's Avatar
Wow that really sucks. I've been thinking about possibly going with the tsp 1 7/8 and this isn't the first time I've read about all these issues. Looks like I'll keep my bbks for a while.
Old Sep 21, 2014 | 11:28 PM
Fry_'s Avatar
Call or email TSP in the morning they'll be happy to help you figure it out.
Old Sep 22, 2014 | 12:20 AM
02DroptopZ's Avatar
Wow, that sounds like a nightmare.. I have the same header/y-pipe setup as you, and my headers hit the k-member in that same spot. I just filed off some excess metal on the k-member and that fixed it.
As for the torque arm and loop, I'm using a BMR relocation crossmember and the y-pipe clears it no problem. (Also using their full length torque arm). My MWC driveshaft loop fits great too, doesn't come anywhere near hitting the y-pipe.
Old Sep 22, 2014 | 05:09 AM
dalejrfan88's Avatar
Did you replace the motor mounts while you were in there? That might be why you are hitting the k-member. I had the same issues with the y-pipe being too long for my Borla catback and had to cut a little bit off.
Old Sep 22, 2014 | 06:03 AM
BrntWS6's Avatar
He said he already has poly mm. Yeah, the MWC DS loop is nice because it goes over instead of under the exhaust. And its lighter than the BMR piece.
Old Sep 22, 2014 | 06:42 AM
DannoWS6's Avatar
Thanks for some of the feedback guys.
Yes I had poly motor mounts in the car for a long time.
I looked up the WMC loop, looks like a nicely clearanced piece that tucks up awesome.
http://www.midwestchassis.com/upload...1332389717.png
That solves one problem I think.
02DroptopZ, you said your BMR relocation bracket works with this Y-pipe? Are you an A4 or M6? what hole are you running the mount in? This yank piece only has one and its a few inches lower than stock location. Pics would be helpful, right now I'm having a hard time visualizing how this will clear unless its stock location. What arm do you have?
I've contemplated going to a short arm but not sure how livable that setup is, plus I already have a nice adjustable spohn arm.
I sent the same info to TSP, guess we'll see how it pans out. I know once you start mixing and matching parts there are no guarantees, frustrating non the less, especially cutting I pipes and grinding stuff.
I hope to get back to it again Tuesday night. I will clearance the primary (drop the header again ughh), then attempt to put my TQ arm back on the tailshaft, if I recall how to put that back together.
Old Sep 22, 2014 | 07:05 AM
MasterV8's Avatar
I have the same issue after doing TSP 1 7/8 header and poly mount install! Rests in the exact same spot & bangs like hell, more so after grinding it because the headers now has more room to vibrate which I thought poly mounts were supposed to stop.
Ive bought a UMI k member to fix that, now just need to install it.
Old Sep 22, 2014 | 07:21 AM
DannoWS6's Avatar
Wow I have no intention of replacing my k-member for this.
I figure with the motor torqueing up into that direction I'd need a good bit of room. I will likely have to grind and bang on the primary
Old Sep 22, 2014 | 09:08 AM
MaSTi's Avatar
You know you want the UMI K-member Dan!!!
Old Sep 22, 2014 | 01:03 PM
BrntWS6's Avatar
MWC also makes a nice long torque arm for the stock 10bolt. It's light, adjustable, and much cheaper than most units available last I checked. I don't know if will fix your problem, give Eric a call he might be familiar with TSP's setup. I have his long arm in my car but with a 9" and it clears my Kooks TD's easily.
Old Sep 22, 2014 | 01:57 PM
02DroptopZ's Avatar
Mines an A4, and I’m using the 3rd hole up from the bottom. I’m also using BMR’s full length arm. I noticed mine looks a lot different than your Spohn arm, that may be part of the problem. Heres some pics, best I could get without the car in the air, hope these help.
Attached Thumbnails TSP 1 7/8 header and Y pipe install problems!-photo.jpg   TSP 1 7/8 header and Y pipe install problems!-photo-4.jpg   TSP 1 7/8 header and Y pipe install problems!-photo-3.jpg
Old Sep 23, 2014 | 05:36 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Clearance the K member. That's normal with these headers. Takes 5 min with a grinder. There's PLENTY of material there. You're simply taking off the excess.
Old Sep 23, 2014 | 06:18 AM
DannoWS6's Avatar
Good info thanks!
In addition to that mount being higher I think the BMR arm is a tiny bit narrower up front.
Tonight I'm gonna go mess with it some more, clearance the k-member to start and see if for now I can mount the TA back to the tranny.
My one other concern is how the merge connects to the intermediate pipe now. Since I cut it I think its has a bit more play, hopefully I can get it setup without leaking everywhere, otherwise I'll have to see if I can get the I pipe necked down.
Old Sep 23, 2014 | 06:43 AM
T/A2000's Avatar
I just installed TSP 1 7/8 headers and their ory, you definitely have to clearance the K member.. not a major deal at all, and mounts will not change that for this set of headers either..
I read a bunch of horror stories about installing these headers after I ordered them, and really thought to myself **** I might have messed up..
But I went ahead and started install anyway, Took off plug wires, oil filter (obviously the old exhaust) and the center bolt out of the mount.
lifted the engine about 1/2 inch and the header fell in, I didn't have to take out the steering shaft, remove the plugs or coils..
Old Sep 23, 2014 | 06:59 AM
T/A2000's Avatar
Originally Posted by DannoWS6
Good info thanks!
you could make two horizontal cuts in the I pipe to aid in making sure it tightens down enough
Old Sep 23, 2014 | 08:27 AM
DannoWS6's Avatar
Yup I did do that, 4 actually.
Glad to know I'm not the only one with clearance issues. Hopefully I can get away with just grinding and I don't need to dimple the header.
Old Sep 23, 2014 | 10:43 AM
dabest09's Avatar
These headers look great at a price point, but I don't want to hack up my car to save a little money. You would think by now TSP would've addressed these issues and made a better fitting header.
Old Sep 23, 2014 | 12:09 PM
dr_whigham's Avatar
The Scammer Hammer
You're not "hacking up" your car. You're shaving about an eighth of an inch of EXCESS METAL from the K member. Trust me, it's really nothing.
Having ran these headers, I can attest to how good the function is of them.
Old Sep 23, 2014 | 07:55 PM
dabest09's Avatar
I know it may not seem like a big deal to some, but I don't like cutting anything that's not necessary on my car to make some poorly designed exhaust fit right.
